Can't install apm planner 2.0 0n lenovo 505s laptop
Hi! I can’t install apm planner 2.0 on my lenovo 505s it runs ubuntu 14.04.please see below
copied text from terminal it seems apm planner needs something called libopenscenegraph80
I tried to install that but when it ask for more files to get libopenscenegraph80 to work…
Is it any easy fix to get things to work? I’m not good at terminal typing so so some icon clicking
would be nice :blush:
Thanks in advance Stefan
stefan@stefan-Lenovo-G505s:~$ sudo dpkg -i apm_planner2_latest_ubuntu64.deb [sudo] password for stefan:
Selecting previously unselected package apmplanner2.
(Reading database … 232302 files and directories currently installed.)
Preparing to unpack apm_planner2_latest_ubuntu64.deb …
Unpacking apmplanner2 (2.0.14) …
dpkg: dependency problems prevent configuration of apmplanner2:
apmplanner2 depends on libopenscenegraph80; however:
Package libopenscenegraph80 is not installed.
dpkg: error processing package apmplanner2 (–install):
dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.10.1-0ubuntu2) …
Processing triggers for desktop-file-utils (0.22-1ubuntu1) …
Processing triggers for bamfdaemon (0.5.1+14.04.20140409-0ubuntu1) …
Rebuilding /usr/share/applications/bamf-2.index…
Processing triggers for mime-support (3.54ubuntu1) …
Errors were encountered while processing:
apmplanner2
stefan@stefan-Lenovo-G505s:~$ sudo apt-get -f install
Reading package lists… Done
Building dependency tree
Reading state information… Done
Correcting dependencies… Done
The following packages were automatically installed and are no longer required:
libavdevice53 libgif4 libgraphicsmagick3 libiso9660-8 libopenthreads14
libpostproc52 libvcdinfo0 libxine1 libxine1-bin libxine1-ffmpeg
libxine1-misc-plugins libxine1-plugins linux-headers-3.13.0-32
linux-headers-3.13.0-32-generic linux-image-3.13.0-32-generic
linux-image-extra-3.13.0-32-generic
Use ‘apt-get autoremove’ to remove them.
The following packages will be REMOVED:
apmplanner2
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 91,8 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database … 233139 files and directories currently installed.)
Removing apmplanner2 (2.0.14) …
apmplanner2
try this download which is built for trusty (14.04) firmware.diydrones.com/Tools/APM … usty64.deb
Thanks for the tip! But I have install Win 7 on the laptop now so I installed
misson planner instead… :blush: So I can’t test that… Sorry :blush:
I have marked it as solved, as i’m 100% sure it was just that you picked up the wrong install file. Thx for your efforts as somebody else will probably find the discussion useful for sure. :smiley:
I confirm that it works great for Lubuntu 14.04.
Thank you Billbonney for your great work :slight_smile:)
Hello, same problem here.
Lenovo Y510P running Kubuntu 14.04.2 LTS, Trusty.
Downloaded current latest “apm_planner2_latest_debian64.deb” from Ardpuilot Downloads and also “apm_planner_2.0.14_ubuntu_trusty64.deb” from Bill’s link above.
Both fail, this is the output for “apm_planner2_latest_debian64.deb”:
[quote]sudo dpkg --install apm_planner2_latest_debian64.deb
(Reading database … 220945 files and directories currently installed.)
Preparing to unpack apm_planner2_latest_debian64.deb …
apmplanner2 depends on libudev0 (>= 0.140); however:
Package libudev0 is not installed.
Processing triggers for mime-support (3.54ubuntu1.1) …
apmplanner2
[/quote]
and the output for “apm_planner_2.0.14_ubuntu_trusty64.deb”:
[quote]sudo dpkg --install apm_planner_2.0.14_ubuntu_trusty64.deb
Preparing to unpack apm_planner_2.0.14_ubuntu_trusty64.deb …
apmplanner2 depends on libopenscenegraph99; however:
Package libopenscenegraph99 is not installed.
apmplanner2[/quote]
Trying to apt-get the missing packages for the first file, “apm_planner2_latest_debian64.deb” fails.
The second file, “apm_planner_2.0.14_ubuntu_trusty64.deb”, installs successfully once the user installs libopenscenegraph99. However, all this song and dance is likely to trip many users (I presume ubuntu is the most common) who will simply follow the ardupilot latest link. Perhaps add some info and extra links in the downloads page?
