romaster93
(woosung cho)
February 9, 2021, 8:21am
1
I am trying to hovering my drone in gazebo using orb slam2.
the slam pose value and local_position/pose value are created well.
However, it cant maintain its posture at 0,0.
Do you have any idea what is the problem?
we used GUIDED MODE at ardupilot and use arm throttle & takeoff 2 command
this is slam picture
this is pose rviz picture
drone cant hovering
You need to use ArduCopter 4.1.0-dev version for that. You need to use EKF3 and have it properly configured.
You need to post your parameter file otherwise we can not guess how you configured your system!
romaster93
(woosung cho)
February 9, 2021, 10:09am
3
now i use ArduCopter 4.1.0-dev.
but I tried to use EKF3 before, but the home position set is still rejected.
This is my parameter file.
Onboard parameters for Vehicle 1
Stack: ArduPilot
Vehicle: Multi-Rotor
Version: 4.1.0 dev
Git Revision: dbae56eb
Vehicle-Id Component-Id Name Value Type
1 1 ACRO_BAL_PITCH 1.000000000000000000 9
1 1 ACRO_BAL_ROLL 1.000000000000000000 9
1 1 ACRO_OPTIONS 0 2
1 1 ACRO_RP_EXPO 0.300000011920928955 9
1 1 ACRO_RP_P 4.500000000000000000 9
1 1 ACRO_THR_MID 0.000000000000000000 9
1 1 ACRO_TRAINER 2 2
1 1 ACRO_YAW_P 4.500000000000000000 9
1 1 ACRO_Y_EXPO 0.000000000000000000 9
1 1 ADSB_TYPE 0 2
1 1 AHRS_COMP_BETA 0.100000001490116119 9
1 1 AHRS_CUSTOM_PIT 0.000000000000000000 9
1 1 AHRS_CUSTOM_ROLL 0.000000000000000000 9
1 1 AHRS_CUSTOM_YAW 0.000000000000000000 9
1 1 AHRS_EKF_TYPE 2 2
1 1 AHRS_GPS_GAIN 1.000000000000000000 9
1 1 AHRS_GPS_MINSATS 6 2
1 1 AHRS_GPS_USE 1 2
1 1 AHRS_ORIENTATION 0 2
1 1 AHRS_RP_P 0.200000002980232239 9
1 1 AHRS_TRIM_X 0.000000000000000000 9
1 1 AHRS_TRIM_Y 0.000000000000000000 9
1 1 AHRS_TRIM_Z 0.000000000000000000 9
1 1 AHRS_WIND_MAX 0 2
1 1 AHRS_YAW_P 0.200000002980232239 9
1 1 ANGLE_MAX 4500 4
1 1 ARMING_ACCTHRESH 0.750000000000000000 9
1 1 ARMING_CHECK 0 6
1 1 ARMING_MIS_ITEMS 0 6
1 1 ARMING_RUDDER 2 2
1 1 ATC_ACCEL_P_MAX 110000.000000000000000000 9
1 1 ATC_ACCEL_R_MAX 110000.000000000000000000 9
1 1 ATC_ACCEL_Y_MAX 27000.000000000000000000 9
1 1 ATC_ANGLE_BOOST 1 2
1 1 ATC_ANG_LIM_TC 1.000000000000000000 9
1 1 ATC_ANG_PIT_P 4.500000000000000000 9
1 1 ATC_ANG_RLL_P 4.500000000000000000 9
1 1 ATC_ANG_YAW_P 4.500000000000000000 9
1 1 ATC_INPUT_TC 0.150000005960464478 9
1 1 ATC_RATE_FF_ENAB 1 2
1 1 ATC_RATE_P_MAX 0.000000000000000000 9
1 1 ATC_RATE_R_MAX 0.000000000000000000 9
1 1 ATC_RATE_Y_MAX 0.000000000000000000 9
1 1 ATC_RAT_PIT_D 0.003599999938160181 9
1 1 ATC_RAT_PIT_FF 0.000000000000000000 9
1 1 ATC_RAT_PIT_FLTD 20.000000000000000000 9
1 1 ATC_RAT_PIT_FLTE 0.000000000000000000 9
1 1 ATC_RAT_PIT_FLTT 20.000000000000000000 9
1 1 ATC_RAT_PIT_I 0.135000005364418030 9
1 1 ATC_RAT_PIT_IMAX 0.500000000000000000 9
1 1 ATC_RAT_PIT_P 0.135000005364418030 9
1 1 ATC_RAT_PIT_SMAX 0.000000000000000000 9
1 1 ATC_RAT_RLL_D 0.003599999938160181 9
1 1 ATC_RAT_RLL_FF 0.000000000000000000 9
1 1 ATC_RAT_RLL_FLTD 20.000000000000000000 9
1 1 ATC_RAT_RLL_FLTE 0.000000000000000000 9
1 1 ATC_RAT_RLL_FLTT 20.000000000000000000 9
1 1 ATC_RAT_RLL_I 0.135000005364418030 9
1 1 ATC_RAT_RLL_IMAX 0.500000000000000000 9
1 1 ATC_RAT_RLL_P 0.135000005364418030 9
1 1 ATC_RAT_RLL_SMAX 0.000000000000000000 9
1 1 ATC_RAT_YAW_D 0.000000000000000000 9
1 1 ATC_RAT_YAW_FF 0.000000000000000000 9
1 1 ATC_RAT_YAW_FLTD 0.000000000000000000 9
1 1 ATC_RAT_YAW_FLTE 2.500000000000000000 9
1 1 ATC_RAT_YAW_FLTT 20.000000000000000000 9
1 1 ATC_RAT_YAW_I 0.017999999225139618 9
1 1 ATC_RAT_YAW_IMAX 0.500000000000000000 9
1 1 ATC_RAT_YAW_P 0.180000007152557373 9
1 1 ATC_RAT_YAW_SMAX 0.000000000000000000 9
1 1 ATC_SLEW_YAW 6000.000000000000000000 9
1 1 ATC_THR_MIX_MAN 0.100000001490116119 9
1 1 ATC_THR_MIX_MAX 0.500000000000000000 9
1 1 ATC_THR_MIX_MIN 0.100000001490116119 9
1 1 AUTOTUNE_AGGR 0.100000001490116119 9
1 1 AUTOTUNE_AXES 7 2
1 1 AUTOTUNE_MIN_D 0.001000000047497451 9
1 1 AUTO_OPTIONS 0 6
1 1 AVD_ENABLE 0 2
1 1 AVOID_ANGLE_MAX 1000 4
1 1 AVOID_BACKUP_SPD 0.500000000000000000 9
1 1 AVOID_BEHAVE 0 2
1 1 AVOID_DIST_MAX 5.000000000000000000 9
1 1 AVOID_ENABLE 3 2
1 1 AVOID_MARGIN 2.000000000000000000 9
1 1 BARO1_DEVID 65540 6
1 1 BARO1_GND_PRESS 94501.328125000000000000 9
1 1 BARO1_WCF_ENABLE 0 2
1 1 BARO2_DEVID 65796 6
1 1 BARO2_GND_PRESS 94501.429687500000000000 9
1 1 BARO2_WCF_ENABLE 0 2
1 1 BARO3_DEVID 0 6
1 1 BARO3_GND_PRESS 0.000000000000000000 9
1 1 BARO3_WCF_ENABLE 0 2
1 1 BARO_ALT_OFFSET 0.000000000000000000 9
1 1 BARO_EXT_BUS -1 2
1 1 BARO_FLTR_RNG 0 2
1 1 BARO_GND_TEMP 0.000000000000000000 9
1 1 BARO_PRIMARY 0 2
1 1 BARO_PROBE_EXT 0 6
1 1 BATT2_MONITOR 0 2
1 1 BATT3_MONITOR 0 2
1 1 BATT4_MONITOR 0 2
1 1 BATT5_MONITOR 0 2
1 1 BATT6_MONITOR 0 2
1 1 BATT7_MONITOR 0 2
1 1 BATT8_MONITOR 0 2
1 1 BATT9_MONITOR 0 2
1 1 BATT_AMP_OFFSET 0.000000000000000000 9
1 1 BATT_AMP_PERVLT 17.000000000000000000 9
1 1 BATT_ARM_MAH 0 6
1 1 BATT_ARM_VOLT 0.000000000000000000 9
1 1 BATT_BUS 0 2
1 1 BATT_CAPACITY 3300 6
1 1 BATT_CRT_MAH 0.000000000000000000 9
1 1 BATT_CRT_VOLT 0.000000000000000000 9
1 1 BATT_CURR_PIN 12 2
1 1 BATT_FS_CRT_ACT 0 2
1 1 BATT_FS_LOW_ACT 0 2
1 1 BATT_FS_VOLTSRC 0 2
1 1 BATT_LOW_MAH 0.000000000000000000 9
1 1 BATT_LOW_TIMER 10 2
1 1 BATT_LOW_VOLT 10.500000000000000000 9
1 1 BATT_MONITOR 4 2
1 1 BATT_OPTIONS 0 6
1 1 BATT_SERIAL_NUM -1 6
1 1 BATT_VOLT_MULT 10.100000381469726563 9
1 1 BATT_VOLT_PIN 13 2
1 1 BCN_ALT 0.000000000000000000 9
1 1 BCN_LATITUDE 0.000000000000000000 9
1 1 BCN_LONGITUDE 0.000000000000000000 9
1 1 BCN_ORIENT_YAW 0 4
1 1 BCN_TYPE 0 2
1 1 BRD_ALT_CONFIG 0 2
1 1 BRD_BOOT_DELAY 0 4
1 1 BRD_OPTIONS 0 6
1 1 BRD_PWM_COUNT 8 2
1 1 BRD_RTC_TYPES 1 2
1 1 BRD_RTC_TZ_MIN 0 4
1 1 BRD_SAFETYOPTION 3 4
1 1 BRD_SERIAL_NUM 0 4
1 1 BRD_VBUS_MIN 4.300000190734863281 9
1 1 BRD_VSERVO_MIN 0.000000000000000000 9
1 1 BTN_ENABLE 0 2
1 1 CAM_AUTO_ONLY 0 2
1 1 CAM_DURATION 10 2
1 1 CAM_FEEDBACK_PIN -1 2
1 1 CAM_FEEDBACK_POL 1 2
1 1 CAM_MAX_ROLL 0 4
1 1 CAM_MIN_INTERVAL 0 4
1 1 CAM_RC_TYPE 0 2
1 1 CAM_RELAY_ON 1 2
1 1 CAM_SERVO_OFF 1100 4
1 1 CAM_SERVO_ON 1300 4
1 1 CAM_TRIGG_DIST 0.000000000000000000 9
1 1 CAM_TRIGG_TYPE 0 2
1 1 CAM_TYPE 0 2
1 1 CAN_D1_PROTOCOL 1 2
1 1 CAN_D2_PROTOCOL 1 2
1 1 CAN_LOGLEVEL 0 2
1 1 CAN_P1_DRIVER 0 2
1 1 CAN_P2_DRIVER 0 2
1 1 CAN_SLCAN_CPORT 0 2
1 1 CAN_SLCAN_SDELAY 1 2
1 1 CAN_SLCAN_SERNUM -1 2
1 1 CAN_SLCAN_TIMOUT 0 2
1 1 CHUTE_ENABLED 0 2
1 1 CIRCLE_OPTIONS 1 4
1 1 CIRCLE_RADIUS 1000.000000000000000000 9
1 1 CIRCLE_RATE 20.000000000000000000 9
1 1 COMPASS_AUTODEC 1 2
1 1 COMPASS_AUTO_ROT 2 2
1 1 COMPASS_CAL_FIT 16.000000000000000000 9
1 1 COMPASS_CUS_PIT 0.000000000000000000 9
1 1 COMPASS_CUS_ROLL 0.000000000000000000 9
1 1 COMPASS_CUS_YAW 0.000000000000000000 9
1 1 COMPASS_DEC 0.000000000000000000 9
1 1 COMPASS_DEV_ID 97539 6
1 1 COMPASS_DEV_ID2 131874 6
1 1 COMPASS_DEV_ID3 263178 6
1 1 COMPASS_DEV_ID4 97283 6
1 1 COMPASS_DEV_ID5 97795 6
1 1 COMPASS_DEV_ID6 98051 6
1 1 COMPASS_DEV_ID7 983044 6
1 1 COMPASS_DEV_ID8 0 6
1 1 COMPASS_DIA2_X 1.000000000000000000 9
1 1 COMPASS_DIA2_Y 1.000000000000000000 9
1 1 COMPASS_DIA2_Z 1.000000000000000000 9
1 1 COMPASS_DIA3_X 1.000000000000000000 9
1 1 COMPASS_DIA3_Y 1.000000000000000000 9
1 1 COMPASS_DIA3_Z 1.000000000000000000 9
1 1 COMPASS_DIA_X 1.000000000000000000 9
1 1 COMPASS_DIA_Y 1.000000000000000000 9
1 1 COMPASS_DIA_Z 1.000000000000000000 9
1 1 COMPASS_ENABLE 1 2
1 1 COMPASS_EXTERN2 0 2
1 1 COMPASS_EXTERN3 0 2
1 1 COMPASS_EXTERNAL 1 2
1 1 COMPASS_FLTR_RNG 0 2
1 1 COMPASS_LEARN 0 2
1 1 COMPASS_MOT2_X 0.000000000000000000 9
1 1 COMPASS_MOT2_Y 0.000000000000000000 9
1 1 COMPASS_MOT2_Z 0.000000000000000000 9
1 1 COMPASS_MOT3_X 0.000000000000000000 9
1 1 COMPASS_MOT3_Y 0.000000000000000000 9
1 1 COMPASS_MOT3_Z 0.000000000000000000 9
1 1 COMPASS_MOTCT 0 2
1 1 COMPASS_MOT_X 0.000000000000000000 9
1 1 COMPASS_MOT_Y 0.000000000000000000 9
1 1 COMPASS_MOT_Z 0.000000000000000000 9
1 1 COMPASS_ODI2_X 0.000000000000000000 9
1 1 COMPASS_ODI2_Y 0.000000000000000000 9
1 1 COMPASS_ODI2_Z 0.000000000000000000 9
1 1 COMPASS_ODI3_X 0.000000000000000000 9
1 1 COMPASS_ODI3_Y 0.000000000000000000 9
1 1 COMPASS_ODI3_Z 0.000000000000000000 9
1 1 COMPASS_ODI_X 0.000000000000000000 9
1 1 COMPASS_ODI_Y 0.000000000000000000 9
1 1 COMPASS_ODI_Z 0.000000000000000000 9
1 1 COMPASS_OFFS_MAX 1800 4
1 1 COMPASS_OFS2_X 5.000000000000000000 9
1 1 COMPASS_OFS2_Y 13.000000000000000000 9
1 1 COMPASS_OFS2_Z -18.000000000000000000 9
1 1 COMPASS_OFS3_X 5.000000000000000000 9
1 1 COMPASS_OFS3_Y 13.000000000000000000 9
1 1 COMPASS_OFS3_Z -18.000000000000000000 9
1 1 COMPASS_OFS_X 5.000000000000000000 9
1 1 COMPASS_OFS_Y 13.000000000000000000 9
1 1 COMPASS_OFS_Z -18.000000000000000000 9
1 1 COMPASS_OPTIONS 0 4
1 1 COMPASS_ORIENT 0 2
1 1 COMPASS_ORIENT2 0 2
1 1 COMPASS_ORIENT3 0 2
1 1 COMPASS_PMOT_EN 0 2
1 1 COMPASS_PRIO1_ID 97539 6
1 1 COMPASS_PRIO2_ID 131874 6
1 1 COMPASS_PRIO3_ID 263178 6
1 1 COMPASS_SCALE 1.000000000000000000 9
1 1 COMPASS_SCALE2 1.000000000000000000 9
1 1 COMPASS_SCALE3 1.000000000000000000 9
1 1 COMPASS_TYPEMASK 0 6
1 1 COMPASS_USE 0 2
1 1 COMPASS_USE2 0 2
1 1 COMPASS_USE3 0 2
1 1 DEV_OPTIONS 0 6
1 1 DISARM_DELAY 10 2
1 1 EAHRS_TYPE 0 2
1 1 EK2_ABIAS_P_NSE 0.004999999888241291 9
1 1 EK2_ACC_P_NSE 0.600000023841857910 9
1 1 EK2_ALT_M_NSE 3.000000000000000000 9
1 1 EK2_ALT_SOURCE 0 2
1 1 EK2_BCN_DELAY 50 2
1 1 EK2_BCN_I_GTE 500 4
1 1 EK2_BCN_M_NSE 1.000000000000000000 9
1 1 EK2_CHECK_SCALE 100 4
1 1 EK2_EAS_I_GATE 400 4
1 1 EK2_EAS_M_NSE 1.399999976158142090 9
1 1 EK2_ENABLE 1 2
1 1 EK2_FLOW_DELAY 10 2
1 1 EK2_FLOW_I_GATE 300 4
1 1 EK2_FLOW_M_NSE 0.250000000000000000 9
1 1 EK2_FLOW_USE 1 2
1 1 EK2_GBIAS_P_NSE 0.000099999997473788 9
1 1 EK2_GLITCH_RAD 25 2
1 1 EK2_GPS_CHECK 31 2
1 1 EK2_GPS_TYPE 3 2
1 1 EK2_GSCL_P_NSE 0.000500000023748726 9
1 1 EK2_GSF_DELAY 1000 4
1 1 EK2_GSF_RST_MAX 2 2
1 1 EK2_GSF_RUN_MASK 3 2
1 1 EK2_GSF_USE_MASK 3 2
1 1 EK2_GYRO_P_NSE 0.029999999329447746 9
1 1 EK2_HGT_DELAY 60 4
1 1 EK2_HGT_I_GATE 500 4
1 1 EK2_HRT_FILT 2.000000000000000000 9
1 1 EK2_IMU_MASK 3 2
1 1 EK2_MAGB_P_NSE 0.000099999997473788 9
1 1 EK2_MAGE_P_NSE 0.001000000047497451 9
1 1 EK2_MAG_CAL 3 2
1 1 EK2_MAG_EF_LIM 50 4
1 1 EK2_MAG_I_GATE 300 4
1 1 EK2_MAG_MASK 0 2
1 1 EK2_MAG_M_NSE 0.050000000745058060 9
1 1 EK2_MAX_FLOW 2.500000000000000000 9
1 1 EK2_NOAID_M_NSE 0.500000000000000000 9
1 1 EK2_OGN_HGT_MASK 0 2
1 1 EK2_POSNE_M_NSE 0.100000001490116119 9
1 1 EK2_POS_I_GATE 500 4
1 1 EK2_RNG_I_GATE 500 4
1 1 EK2_RNG_M_NSE 0.500000000000000000 9
1 1 EK2_RNG_USE_HGT -1 2
1 1 EK2_RNG_USE_SPD 2.000000000000000000 9
1 1 EK2_TAU_OUTPUT 25 2
1 1 EK2_TERR_GRAD 0.100000001490116119 9
1 1 EK2_VELD_M_NSE 0.100000001490116119 9
1 1 EK2_VELNE_M_NSE 0.100000001490116119 9
1 1 EK2_VEL_I_GATE 500 4
1 1 EK2_WIND_PSCALE 0.500000000000000000 9
1 1 EK2_WIND_P_NSE 0.100000001490116119 9
1 1 EK2_YAW_I_GATE 300 4
1 1 EK2_YAW_M_NSE 0.500000000000000000 9
1 1 EK3_ENABLE 0 2
1 1 ESC_CALIBRATION 0 2
1 1 FENCE_ACTION 1 2
1 1 FENCE_ALT_MAX 100.000000000000000000 9
1 1 FENCE_ENABLE 0 2
1 1 FENCE_MARGIN 2.000000000000000000 9
1 1 FENCE_RADIUS 150.000000000000000000 9
1 1 FENCE_TOTAL 0 2
1 1 FENCE_TYPE 7 2
1 1 FFT_ENABLE 0 2
1 1 FHLD_BRAKE_RATE 8 2
1 1 FHLD_FILT_HZ 5.000000000000000000 9
1 1 FHLD_FLOW_MAX 0.600000023841857910 9
1 1 FHLD_QUAL_MIN 10 2
1 1 FHLD_XY_FILT_HZ 5.000000000000000000 9
1 1 FHLD_XY_I 0.300000011920928955 9
1 1 FHLD_XY_IMAX 3000.000000000000000000 9
1 1 FHLD_XY_P 0.200000002980232239 9
1 1 FLOW_ADDR 0 2
1 1 FLOW_FXSCALER 0 4
1 1 FLOW_FYSCALER 0 4
1 1 FLOW_ORIENT_YAW 0 4
1 1 FLOW_POS_X 0.000000000000000000 9
1 1 FLOW_POS_Y 0.000000000000000000 9
1 1 FLOW_POS_Z 0.000000000000000000 9
1 1 FLOW_TYPE 0 2
1 1 FLTMODE1 7 2
1 1 FLTMODE2 9 2
1 1 FLTMODE3 6 2
1 1 FLTMODE4 3 2
1 1 FLTMODE5 5 2
1 1 FLTMODE6 0 2
1 1 FLTMODE_CH 5 2
1 1 FOLL_ENABLE 0 2
1 1 FORMAT_VERSION 120 4
1 1 FRAME_CLASS 1 2
1 1 FRAME_TYPE 1 2
1 1 FRSKY_DNLINK1_ID 20 2
1 1 FRSKY_DNLINK2_ID 7 2
1 1 FRSKY_UPLINK_ID 13 2
1 1 FS_CRASH_CHECK 1 2
1 1 FS_EKF_ACTION 1 2
1 1 FS_EKF_THRESH 0.000000000000000000 9
1 1 FS_GCS_ENABLE 0 2
1 1 FS_GCS_TIMEOUT 5.000000000000000000 9
1 1 FS_OPTIONS 16 6
1 1 FS_THR_ENABLE 1 2
1 1 FS_THR_VALUE 975 4
1 1 FS_VIBE_ENABLE 1 2
1 1 GCS_PID_MASK 0 4
1 1 GEN_TYPE 0 2
1 1 GND_EFFECT_COMP 1 2
1 1 GPS_AUTO_CONFIG 1 2
1 1 GPS_AUTO_SWITCH 1 2
1 1 GPS_BLEND_MASK 5 2
1 1 GPS_BLEND_TC 10.000000000000000000 9
1 1 GPS_COM_PORT 1 2
1 1 GPS_COM_PORT2 1 2
1 1 GPS_DELAY_MS 0 4
1 1 GPS_DELAY_MS2 0 4
1 1 GPS_DRV_OPTIONS 0 4
1 1 GPS_GNSS_MODE 0 2
1 1 GPS_GNSS_MODE2 0 2
1 1 GPS_HDOP_GOOD 140 4
1 1 GPS_INJECT_TO 127 2
1 1 GPS_MB1_TYPE 0 2
1 1 GPS_MB2_TYPE 0 2
1 1 GPS_MIN_DGPS 100 2
1 1 GPS_MIN_ELEV -100 2
1 1 GPS_NAVFILTER 8 2
1 1 GPS_POS1_X 0.000000000000000000 9
1 1 GPS_POS1_Y 0.000000000000000000 9
1 1 GPS_POS1_Z 0.000000000000000000 9
1 1 GPS_POS2_X 0.000000000000000000 9
1 1 GPS_POS2_Y 0.000000000000000000 9
1 1 GPS_POS2_Z 0.000000000000000000 9
1 1 GPS_PRIMARY 0 2
1 1 GPS_RATE_MS 200 4
1 1 GPS_RATE_MS2 200 4
1 1 GPS_RAW_DATA 0 2
1 1 GPS_SAVE_CFG 2 2
1 1 GPS_SBAS_MODE 2 2
1 1 GPS_SBP_LOGMASK -256 4
1 1 GPS_TYPE 0 2
1 1 GPS_TYPE2 0 2
1 1 GRIP_ENABLE 0 2
1 1 GUID_OPTIONS 0 6
1 1 INITIAL_MODE 0 2
1 1 INS_ACC1_CALTEMP -300.000000000000000000 9
1 1 INS_ACC2OFFS_X 0.001000000047497451 9
1 1 INS_ACC2OFFS_Y 0.001000000047497451 9
1 1 INS_ACC2OFFS_Z 0.001000000047497451 9
1 1 INS_ACC2SCAL_X 1.001000046730041504 9
1 1 INS_ACC2SCAL_Y 1.001000046730041504 9
1 1 INS_ACC2SCAL_Z 1.001000046730041504 9
1 1 INS_ACC2_CALTEMP -300.000000000000000000 9
1 1 INS_ACC2_ID 2753036 6
1 1 INS_ACC3OFFS_X 0.000000000000000000 9
1 1 INS_ACC3OFFS_Y 0.000000000000000000 9
1 1 INS_ACC3OFFS_Z 0.000000000000000000 9
1 1 INS_ACC3SCAL_X 1.000000000000000000 9
1 1 INS_ACC3SCAL_Y 1.000000000000000000 9
1 1 INS_ACC3SCAL_Z 1.000000000000000000 9
1 1 INS_ACC3_CALTEMP -300.000000000000000000 9
1 1 INS_ACC3_ID 0 6
1 1 INS_ACCEL_FILTER 20 4
1 1 INS_ACCOFFS_X 0.001000000047497451 9
1 1 INS_ACCOFFS_Y 0.001000000047497451 9
1 1 INS_ACCOFFS_Z 0.001000000047497451 9
1 1 INS_ACCSCAL_X 1.001000046730041504 9
1 1 INS_ACCSCAL_Y 1.001000046730041504 9
1 1 INS_ACCSCAL_Z 1.001000046730041504 9
1 1 INS_ACC_BODYFIX 2 2
1 1 INS_ACC_ID 2753028 6
1 1 INS_ENABLE_MASK 127 2
1 1 INS_FAST_SAMPLE 1 2
1 1 INS_GYR1_CALTEMP 25.049049377441406250 9
1 1 INS_GYR2OFFS_X 0.001198860118165612 9
1 1 INS_GYR2OFFS_Y 0.001416343031451106 9
1 1 INS_GYR2OFFS_Z 0.001229060813784599 9
1 1 INS_GYR2_CALTEMP 25.049049377441406250 9
1 1 INS_GYR2_ID 2752780 6
1 1 INS_GYR3OFFS_X 0.000000000000000000 9
1 1 INS_GYR3OFFS_Y 0.000000000000000000 9
1 1 INS_GYR3OFFS_Z 0.000000000000000000 9
1 1 INS_GYR3_CALTEMP -300.000000000000000000 9
1 1 INS_GYR3_ID 0 6
1 1 INS_GYROFFS_X 0.001206754241138697 9
1 1 INS_GYROFFS_Y 0.001515510724857450 9
1 1 INS_GYROFFS_Z 0.001278059091418982 9
1 1 INS_GYRO_FILTER 20 4
1 1 INS_GYRO_RATE 0 2
1 1 INS_GYR_CAL 1 2
1 1 INS_GYR_ID 2752772 6
1 1 INS_HNTCH_ENABLE 0 2
1 1 INS_LOG_BAT_CNT 1024 4
1 1 INS_LOG_BAT_LGCT 32 4
1 1 INS_LOG_BAT_LGIN 20 2
1 1 INS_LOG_BAT_MASK 0 2
1 1 INS_LOG_BAT_OPT 0 2
1 1 INS_NOTCH_ENABLE 0 2
1 1 INS_POS1_X 0.000000000000000000 9
1 1 INS_POS1_Y 0.000000000000000000 9
1 1 INS_POS1_Z 0.000000000000000000 9
1 1 INS_POS2_X 0.000000000000000000 9
1 1 INS_POS2_Y 0.000000000000000000 9
1 1 INS_POS2_Z 0.000000000000000000 9
1 1 INS_POS3_X 0.000000000000000000 9
1 1 INS_POS3_Y 0.000000000000000000 9
1 1 INS_POS3_Z 0.000000000000000000 9
1 1 INS_STILL_THRESH 2.500000000000000000 9
1 1 INS_TCAL1_ENABLE 0 2
1 1 INS_TCAL2_ENABLE 0 2
1 1 INS_TCAL3_ENABLE 0 2
1 1 INS_TCAL_OPTIONS 0 6
1 1 INS_TRIM_OPTION 1 2
1 1 INS_USE 1 2
1 1 INS_USE2 1 2
1 1 INS_USE3 1 2
1 1 LAND_ALT_LOW 1000 4
1 1 LAND_REPOSITION 1 2
1 1 LAND_SPEED 50 4
1 1 LAND_SPEED_HIGH 0 4
1 1 LGR_DEPLOY_ALT 0 4
1 1 LGR_DEPLOY_PIN -1 2
1 1 LGR_DEPLOY_POL 0 2
1 1 LGR_OPTIONS 3 4
1 1 LGR_RETRACT_ALT 0 4
1 1 LGR_STARTUP 0 2
1 1 LGR_WOW_PIN 8 2
1 1 LGR_WOW_POL 1 2
1 1 LOG_BACKEND_TYPE 1 2
1 1 LOG_BITMASK 176126 6
1 1 LOG_DISARMED 0 2
1 1 LOG_FILE_BUFSIZE 200 4
1 1 LOG_FILE_DSRMROT 0 2
1 1 LOG_FILE_MB_FREE 500 4
1 1 LOG_FILE_TIMEOUT 5 4
1 1 LOG_MAV_BUFSIZE 8 2
1 1 LOG_REPLAY 0 2
1 1 LOIT_ACC_MAX 500.000000000000000000 9
1 1 LOIT_ANG_MAX 0.000000000000000000 9
1 1 LOIT_BRK_ACCEL 250.000000000000000000 9
1 1 LOIT_BRK_DELAY 1.000000000000000000 9
1 1 LOIT_BRK_JERK 500.000000000000000000 9
1 1 LOIT_SPEED 1250.000000000000000000 9
1 1 MIS_OPTIONS 0 4
1 1 MIS_RESTART 0 2
1 1 MIS_TOTAL 0 4
1 1 MNT_ANGMAX_PAN 4500 4
1 1 MNT_ANGMAX_ROL 4500 4
1 1 MNT_ANGMAX_TIL 4500 4
1 1 MNT_ANGMIN_PAN -4500 4
1 1 MNT_ANGMIN_ROL -4500 4
1 1 MNT_ANGMIN_TIL -4500 4
1 1 MNT_DEFLT_MODE 3 2
1 1 MNT_JSTICK_SPD 0 2
1 1 MNT_LEAD_PTCH 0.000000000000000000 9
1 1 MNT_LEAD_RLL 0.000000000000000000 9
1 1 MNT_NEUTRAL_X 0.000000000000000000 9
1 1 MNT_NEUTRAL_Y 0.000000000000000000 9
1 1 MNT_NEUTRAL_Z 0.000000000000000000 9
1 1 MNT_RC_IN_PAN 0 2
1 1 MNT_RC_IN_ROLL 0 2
1 1 MNT_RC_IN_TILT 0 2
1 1 MNT_RETRACT_X 0.000000000000000000 9
1 1 MNT_RETRACT_Y 0.000000000000000000 9
1 1 MNT_RETRACT_Z 0.000000000000000000 9
1 1 MNT_STAB_PAN 0 2
1 1 MNT_STAB_ROLL 0 2
1 1 MNT_STAB_TILT 0 2
1 1 MNT_TYPE 0 2
1 1 MOT_BAT_CURR_MAX 0.000000000000000000 9
1 1 MOT_BAT_CURR_TC 5.000000000000000000 9
1 1 MOT_BAT_IDX 0 2
1 1 MOT_BAT_VOLT_MAX 12.800000190734863281 9
1 1 MOT_BAT_VOLT_MIN 9.600000381469726563 9
1 1 MOT_BOOST_SCALE 0.000000000000000000 9
1 1 MOT_HOVER_LEARN 2 2
1 1 MOT_PWM_MAX 2000 4
1 1 MOT_PWM_MIN 1000 4
1 1 MOT_PWM_TYPE 0 2
1 1 MOT_SAFE_DISARM 0 2
1 1 MOT_SAFE_TIME 1.000000000000000000 9
1 1 MOT_SLEW_DN_TIME 0.000000000000000000 9
1 1 MOT_SLEW_UP_TIME 0.000000000000000000 9
1 1 MOT_SPIN_ARM 0.100000001490116119 9
1 1 MOT_SPIN_MAX 0.949999988079071045 9
1 1 MOT_SPIN_MIN 0.150000005960464478 9
1 1 MOT_SPOOL_TIME 0.500000000000000000 9
1 1 MOT_THST_EXPO 0.649999976158142090 9
1 1 MOT_THST_HOVER 0.146957129240036011 9
1 1 MOT_YAW_HEADROOM 200 4
1 1 MSP_OPTIONS 0 2
1 1 MSP_OSD_NCELLS 0 2
1 1 NTF_BUZZ_ENABLE 1 2
1 1 NTF_BUZZ_ON_LVL 1 2
1 1 NTF_BUZZ_PIN 0 2
1 1 NTF_BUZZ_VOLUME 100 2
1 1 NTF_DISPLAY_TYPE 0 2
1 1 NTF_LED_BRIGHT 3 2
1 1 NTF_LED_LEN 1 2
1 1 NTF_LED_OVERRIDE 0 2
1 1 NTF_LED_TYPES 199 6
1 1 NTF_OREO_THEME 0 2
1 1 OA_TYPE 0 2
1 1 OSD_TYPE 0 2
1 1 PHLD_BRAKE_ANGLE 3000 4
1 1 PHLD_BRAKE_RATE 8 4
1 1 PILOT_ACCEL_Z 250 4
1 1 PILOT_SPEED_DN 0 4
1 1 PILOT_SPEED_UP 250 4
1 1 PILOT_THR_BHV 0 4
1 1 PILOT_THR_FILT 0.000000000000000000 9
1 1 PILOT_TKOFF_ALT 0.000000000000000000 9
1 1 PLND_ACC_P_NSE 2.500000000000000000 9
1 1 PLND_BUS -1 2
1 1 PLND_CAM_POS_X 0.000000000000000000 9
1 1 PLND_CAM_POS_Y 0.000000000000000000 9
1 1 PLND_CAM_POS_Z 0.000000000000000000 9
1 1 PLND_ENABLED 1 2
1 1 PLND_EST_TYPE 1 2
1 1 PLND_LAG 0.019999999552965164 9
1 1 PLND_LAND_OFS_X 0.000000000000000000 9
1 1 PLND_LAND_OFS_Y 0.000000000000000000 9
1 1 PLND_TYPE 3 2
1 1 PLND_YAW_ALIGN 0.000000000000000000 9
1 1 PRX_IGN_ANG1 0 4
1 1 PRX_IGN_ANG2 0 4
1 1 PRX_IGN_ANG3 0 4
1 1 PRX_IGN_ANG4 0 4
1 1 PRX_IGN_ANG5 0 4
1 1 PRX_IGN_ANG6 0 4
1 1 PRX_IGN_WID1 0 2
1 1 PRX_IGN_WID2 0 2
1 1 PRX_IGN_WID3 0 2
1 1 PRX_IGN_WID4 0 2
1 1 PRX_IGN_WID5 0 2
1 1 PRX_IGN_WID6 0 2
1 1 PRX_ORIENT 0 2
1 1 PRX_TYPE 2 2
1 1 PRX_YAW_CORR 0 4
1 1 PSC_ACCZ_D 0.000000000000000000 9
1 1 PSC_ACCZ_FF 0.000000000000000000 9
1 1 PSC_ACCZ_FLTD 0.000000000000000000 9
1 1 PSC_ACCZ_FLTE 20.000000000000000000 9
1 1 PSC_ACCZ_FLTT 0.000000000000000000 9
1 1 PSC_ACCZ_I 1.000000000000000000 9
1 1 PSC_ACCZ_IMAX 800.000000000000000000 9
1 1 PSC_ACCZ_P 0.500000000000000000 9
1 1 PSC_ACCZ_SMAX 0.000000000000000000 9
1 1 PSC_ACC_XY_FILT 2.000000000000000000 9
1 1 PSC_ANGLE_MAX 0.000000000000000000 9
1 1 PSC_POSXY_P 1.000000000000000000 9
1 1 PSC_POSZ_P 1.000000000000000000 9
1 1 PSC_VELXY_D 0.500000000000000000 9
1 1 PSC_VELXY_D_FILT 5.000000000000000000 9
1 1 PSC_VELXY_FILT 5.000000000000000000 9
1 1 PSC_VELXY_I 1.000000000000000000 9
1 1 PSC_VELXY_IMAX 1000.000000000000000000 9
1 1 PSC_VELXY_P 2.000000000000000000 9
1 1 PSC_VELZ_P 5.000000000000000000 9
1 1 RALLY_INCL_HOME 1 2
1 1 RALLY_LIMIT_KM 0.300000011920928955 9
1 1 RALLY_TOTAL 0 2
1 1 RC10_DZ 0 4
1 1 RC10_MAX 1900 4
1 1 RC10_MIN 1100 4
1 1 RC10_OPTION 0 4
1 1 RC10_REVERSED 0 2
1 1 RC10_TRIM 1500 4
1 1 RC11_DZ 0 4
1 1 RC11_MAX 1900 4
1 1 RC11_MIN 1100 4
1 1 RC11_OPTION 0 4
1 1 RC11_REVERSED 0 2
1 1 RC11_TRIM 1500 4
1 1 RC12_DZ 0 4
1 1 RC12_MAX 1900 4
1 1 RC12_MIN 1100 4
1 1 RC12_OPTION 0 4
1 1 RC12_REVERSED 0 2
1 1 RC12_TRIM 1500 4
1 1 RC13_DZ 0 4
1 1 RC13_MAX 1900 4
1 1 RC13_MIN 1100 4
1 1 RC13_OPTION 0 4
1 1 RC13_REVERSED 0 2
1 1 RC13_TRIM 1500 4
1 1 RC14_DZ 0 4
1 1 RC14_MAX 1900 4
1 1 RC14_MIN 1100 4
1 1 RC14_OPTION 0 4
1 1 RC14_REVERSED 0 2
1 1 RC14_TRIM 1500 4
1 1 RC15_DZ 0 4
1 1 RC15_MAX 1900 4
1 1 RC15_MIN 1100 4
1 1 RC15_OPTION 0 4
1 1 RC15_REVERSED 0 2
1 1 RC15_TRIM 1500 4
1 1 RC16_DZ 0 4
1 1 RC16_MAX 1900 4
1 1 RC16_MIN 1100 4
1 1 RC16_OPTION 0 4
1 1 RC16_REVERSED 0 2
1 1 RC16_TRIM 1500 4
1 1 RC1_DZ 20 4
1 1 RC1_MAX 2000 4
1 1 RC1_MIN 1000 4
1 1 RC1_OPTION 0 4
1 1 RC1_REVERSED 0 2
1 1 RC1_TRIM 1500 4
1 1 RC2_DZ 20 4
1 1 RC2_MAX 2000 4
1 1 RC2_MIN 1000 4
1 1 RC2_OPTION 0 4
1 1 RC2_REVERSED 0 2
1 1 RC2_TRIM 1500 4
1 1 RC3_DZ 30 4
1 1 RC3_MAX 2000 4
1 1 RC3_MIN 1000 4
1 1 RC3_OPTION 0 4
1 1 RC3_REVERSED 0 2
1 1 RC3_TRIM 1500 4
1 1 RC4_DZ 20 4
1 1 RC4_MAX 2000 4
1 1 RC4_MIN 1000 4
1 1 RC4_OPTION 0 4
1 1 RC4_REVERSED 0 2
1 1 RC4_TRIM 1500 4
1 1 RC5_DZ 0 4
1 1 RC5_MAX 2000 4
1 1 RC5_MIN 1000 4
1 1 RC5_OPTION 0 4
1 1 RC5_REVERSED 0 2
1 1 RC5_TRIM 1500 4
1 1 RC6_DZ 0 4
1 1 RC6_MAX 2000 4
1 1 RC6_MIN 1000 4
1 1 RC6_OPTION 0 4
1 1 RC6_REVERSED 0 2
1 1 RC6_TRIM 1500 4
1 1 RC7_DZ 0 4
1 1 RC7_MAX 2000 4
1 1 RC7_MIN 1000 4
1 1 RC7_OPTION 7 4
1 1 RC7_REVERSED 0 2
1 1 RC7_TRIM 1500 4
1 1 RC8_DZ 0 4
1 1 RC8_MAX 2000 4
1 1 RC8_MIN 1000 4
1 1 RC8_OPTION 39 4
1 1 RC8_REVERSED 0 2
1 1 RC8_TRIM 1500 4
1 1 RC9_DZ 0 4
1 1 RC9_MAX 1900 4
1 1 RC9_MIN 1100 4
1 1 RC9_OPTION 0 4
1 1 RC9_REVERSED 0 2
1 1 RC9_TRIM 1500 4
1 1 RCMAP_PITCH 2 2
1 1 RCMAP_ROLL 1 2
1 1 RCMAP_THROTTLE 3 2
1 1 RCMAP_YAW 4 2
1 1 RC_OPTIONS 32 6
1 1 RC_OVERRIDE_TIME 3.000000000000000000 9
1 1 RC_PROTOCOLS 1 6
1 1 RC_SPEED 490 4
1 1 RELAY_DEFAULT 0 2
1 1 RELAY_PIN 13 2
1 1 RELAY_PIN2 -1 2
1 1 RELAY_PIN3 -1 2
1 1 RELAY_PIN4 -1 2
1 1 RELAY_PIN5 -1 2
1 1 RELAY_PIN6 -1 2
1 1 RNGFND1_ADDR 0 2
1 1 RNGFND1_FUNCTION 0 2
1 1 RNGFND1_GNDCLEAR 10 2
1 1 RNGFND1_MAX_CM 5000 4
1 1 RNGFND1_MIN_CM 20 4
1 1 RNGFND1_OFFSET 0.000000000000000000 9
1 1 RNGFND1_ORIENT 25 2
1 1 RNGFND1_PIN 0 2
1 1 RNGFND1_POS_X 0.000000000000000000 9
1 1 RNGFND1_POS_Y 0.000000000000000000 9
1 1 RNGFND1_POS_Z 0.000000000000000000 9
1 1 RNGFND1_PWRRNG 0 4
1 1 RNGFND1_RMETRIC 1 2
1 1 RNGFND1_SCALING 10.000000000000000000 9
1 1 RNGFND1_STOP_PIN -1 2
1 1 RNGFND1_TYPE 1 2
1 1 RNGFND2_TYPE 0 2
1 1 RNGFND3_TYPE 0 2
1 1 RNGFND4_TYPE 0 2
1 1 RNGFND5_TYPE 0 2
1 1 RNGFND6_TYPE 0 2
1 1 RNGFND7_TYPE 0 2
1 1 RNGFND8_TYPE 0 2
1 1 RNGFND9_TYPE 0 2
1 1 RNGFNDA_TYPE 0 2
1 1 RNGFND_GAIN 0.800000011920928955 9
1 1 RPM2_PIN -1 2
1 1 RPM2_SCALING 1.000000000000000000 9
1 1 RPM2_TYPE 0 2
1 1 RPM_MAX 100000.000000000000000000 9
1 1 RPM_MIN 10.000000000000000000 9
1 1 RPM_MIN_QUAL 0.500000000000000000 9
1 1 RPM_PIN 54 2
1 1 RPM_SCALING 1.000000000000000000 9
1 1 RPM_TYPE 0 2
1 1 RSSI_TYPE 0 2
1 1 RTL_ALT 1500 4
1 1 RTL_ALT_FINAL 0 4
1 1 RTL_ALT_TYPE 0 2
1 1 RTL_CLIMB_MIN 0 4
1 1 RTL_CONE_SLOPE 3.000000000000000000 9
1 1 RTL_LOIT_TIME 5000 6
1 1 RTL_OPTIONS 0 6
1 1 RTL_SPEED 0 4
1 1 SCHED_DEBUG 0 2
1 1 SCHED_LOOP_RATE 400 4
1 1 SCHED_OPTIONS 0 2
1 1 SCR_ENABLE 0 2
1 1 SERIAL0_BAUD 115 6
1 1 SERIAL0_PROTOCOL 2 2
1 1 SERIAL1_BAUD 57 6
1 1 SERIAL1_OPTIONS 0 4
1 1 SERIAL1_PROTOCOL 2 2
1 1 SERIAL2_BAUD 57 6
1 1 SERIAL2_OPTIONS 0 4
1 1 SERIAL2_PROTOCOL 2 2
1 1 SERIAL3_BAUD 38 6
1 1 SERIAL3_OPTIONS 0 4
1 1 SERIAL3_PROTOCOL 5 2
1 1 SERIAL4_BAUD 38 6
1 1 SERIAL4_OPTIONS 0 4
1 1 SERIAL4_PROTOCOL 5 2
1 1 SERIAL5_BAUD 57 6
1 1 SERIAL5_OPTIONS 0 4
1 1 SERIAL5_PROTOCOL -1 2
1 1 SERIAL6_BAUD 57 6
1 1 SERIAL6_OPTIONS 0 4
1 1 SERIAL6_PROTOCOL -1 2
1 1 SERIAL7_BAUD 57 6
1 1 SERIAL7_OPTIONS 0 4
1 1 SERIAL7_PROTOCOL -1 2
1 1 SERIAL_PASS1 0 2
1 1 SERIAL_PASS2 -1 2
1 1 SERIAL_PASSTIMO 15 2
1 1 SERVO10_FUNCTION 0 4
1 1 SERVO10_MAX 1900 4
1 1 SERVO10_MIN 1100 4
1 1 SERVO10_REVERSED 0 2
1 1 SERVO10_TRIM 1500 4
1 1 SERVO11_FUNCTION 0 4
1 1 SERVO11_MAX 1900 4
1 1 SERVO11_MIN 1100 4
1 1 SERVO11_REVERSED 0 2
1 1 SERVO11_TRIM 1500 4
1 1 SERVO12_FUNCTION 0 4
1 1 SERVO12_MAX 1900 4
1 1 SERVO12_MIN 1100 4
1 1 SERVO12_REVERSED 0 2
1 1 SERVO12_TRIM 1500 4
1 1 SERVO13_FUNCTION 0 4
1 1 SERVO13_MAX 1900 4
1 1 SERVO13_MIN 1100 4
1 1 SERVO13_REVERSED 0 2
1 1 SERVO13_TRIM 1500 4
1 1 SERVO14_FUNCTION 0 4
1 1 SERVO14_MAX 1900 4
1 1 SERVO14_MIN 1100 4
1 1 SERVO14_REVERSED 0 2
1 1 SERVO14_TRIM 1500 4
1 1 SERVO15_FUNCTION 0 4
1 1 SERVO15_MAX 1900 4
1 1 SERVO15_MIN 1100 4
1 1 SERVO15_REVERSED 0 2
1 1 SERVO15_TRIM 1500 4
1 1 SERVO16_FUNCTION 0 4
1 1 SERVO16_MAX 1900 4
1 1 SERVO16_MIN 1100 4
1 1 SERVO16_REVERSED 0 2
1 1 SERVO16_TRIM 1500 4
1 1 SERVO1_FUNCTION 33 4
1 1 SERVO1_MAX 1900 4
1 1 SERVO1_MIN 1100 4
1 1 SERVO1_REVERSED 0 2
1 1 SERVO1_TRIM 1500 4
1 1 SERVO2_FUNCTION 34 4
1 1 SERVO2_MAX 1900 4
1 1 SERVO2_MIN 1100 4
1 1 SERVO2_REVERSED 0 2
1 1 SERVO2_TRIM 1500 4
1 1 SERVO3_FUNCTION 35 4
1 1 SERVO3_MAX 1900 4
1 1 SERVO3_MIN 1100 4
1 1 SERVO3_REVERSED 0 2
1 1 SERVO3_TRIM 1500 4
1 1 SERVO4_FUNCTION 36 4
1 1 SERVO4_MAX 1900 4
1 1 SERVO4_MIN 1100 4
1 1 SERVO4_REVERSED 0 2
1 1 SERVO4_TRIM 1500 4
1 1 SERVO5_FUNCTION 0 4
1 1 SERVO5_MAX 1900 4
1 1 SERVO5_MIN 1100 4
1 1 SERVO5_REVERSED 0 2
1 1 SERVO5_TRIM 1500 4
1 1 SERVO6_FUNCTION 0 4
1 1 SERVO6_MAX 1900 4
1 1 SERVO6_MIN 1100 4
1 1 SERVO6_REVERSED 0 2
1 1 SERVO6_TRIM 1500 4
1 1 SERVO7_FUNCTION 0 4
1 1 SERVO7_MAX 1900 4
1 1 SERVO7_MIN 1100 4
1 1 SERVO7_REVERSED 0 2
1 1 SERVO7_TRIM 1500 4
1 1 SERVO8_FUNCTION 0 4
1 1 SERVO8_MAX 1900 4
1 1 SERVO8_MIN 1100 4
1 1 SERVO8_REVERSED 0 2
1 1 SERVO8_TRIM 1500 4
1 1 SERVO9_FUNCTION 0 4
1 1 SERVO9_MAX 1900 4
1 1 SERVO9_MIN 1100 4
1 1 SERVO9_REVERSED 0 2
1 1 SERVO9_TRIM 1500 4
1 1 SERVO_RATE 50 4
1 1 SERVO_ROB_POSMAX 4095 6
1 1 SERVO_ROB_POSMIN 0 6
1 1 SERVO_SBUS_RATE 50 4
1 1 SERVO_VOLZ_MASK 0 6
1 1 SID_AXIS 0 2
1 1 SIMPLE 0 2
1 1 SIM_ACC1_BIAS_X 0.000000000000000000 9
1 1 SIM_ACC1_BIAS_Y 0.000000000000000000 9
1 1 SIM_ACC1_BIAS_Z 0.000000000000000000 9
1 1 SIM_ACC1_RND 0.000000000000000000 9
1 1 SIM_ACC1_SCAL_X 0.000000000000000000 9
1 1 SIM_ACC1_SCAL_Y 0.000000000000000000 9
1 1 SIM_ACC1_SCAL_Z 0.000000000000000000 9
1 1 SIM_ACC2_BIAS_X 0.000000000000000000 9
1 1 SIM_ACC2_BIAS_Y 0.000000000000000000 9
1 1 SIM_ACC2_BIAS_Z 0.000000000000000000 9
1 1 SIM_ACC2_RND 0.000000000000000000 9
1 1 SIM_ACC2_SCAL_X 0.000000000000000000 9
1 1 SIM_ACC2_SCAL_Y 0.000000000000000000 9
1 1 SIM_ACC2_SCAL_Z 0.000000000000000000 9
1 1 SIM_ACC3_BIAS_X 0.000000000000000000 9
1 1 SIM_ACC3_BIAS_Y 0.000000000000000000 9
1 1 SIM_ACC3_BIAS_Z 0.000000000000000000 9
1 1 SIM_ACC3_RND 0.000000000000000000 9
1 1 SIM_ACC3_SCAL_X 0.000000000000000000 9
1 1 SIM_ACC3_SCAL_Y 0.000000000000000000 9
1 1 SIM_ACC3_SCAL_Z 0.000000000000000000 9
1 1 SIM_ACCEL1_FAIL 0.000000000000000000 9
1 1 SIM_ACCEL2_FAIL 0.000000000000000000 9
1 1 SIM_ACCEL3_FAIL 0.000000000000000000 9
1 1 SIM_ACC_FAIL_MSK 0 2
1 1 SIM_ACC_TRIM_X 0.000000000000000000 9
1 1 SIM_ACC_TRIM_Y 0.000000000000000000 9
1 1 SIM_ACC_TRIM_Z 0.000000000000000000 9
1 1 SIM_ADSB_ALT 1000.000000000000000000 9
1 1 SIM_ADSB_COUNT -1 4
1 1 SIM_ADSB_RADIUS 10000.000000000000000000 9
1 1 SIM_ADSB_TX 0 2
1 1 SIM_ARSPD2_FAIL 0.000000000000000000 9
1 1 SIM_ARSPD2_FAILP 0.000000000000000000 9
1 1 SIM_ARSPD2_OFS 2013.000000000000000000 9
1 1 SIM_ARSPD2_PITOT 0.000000000000000000 9
1 1 SIM_ARSPD2_RND 2.000000000000000000 9
1 1 SIM_ARSPD_FAIL 0.000000000000000000 9
1 1 SIM_ARSPD_FAILP 0.000000000000000000 9
1 1 SIM_ARSPD_OFS 2013.000000000000000000 9
1 1 SIM_ARSPD_PITOT 0.000000000000000000 9
1 1 SIM_ARSPD_RND 2.000000000000000000 9
1 1 SIM_ARSPD_SIGN 0 2
1 1 SIM_BAR2_DELAY 0 4
1 1 SIM_BAR2_DISABLE 0 2
1 1 SIM_BAR2_DRIFT 0.000000000000000000 9
1 1 SIM_BAR2_FREEZE 0 2
1 1 SIM_BAR2_GLITCH 0.000000000000000000 9
1 1 SIM_BAR2_RND 0.200000002980232239 9
1 1 SIM_BAR2_WCF_BAK 0.000000000000000000 9
1 1 SIM_BAR2_WCF_FWD 0.000000000000000000 9
1 1 SIM_BAR2_WCF_LFT 0.000000000000000000 9
1 1 SIM_BAR2_WCF_RGT 0.000000000000000000 9
1 1 SIM_BAR3_DELAY 0 4
1 1 SIM_BAR3_DISABLE 0 2
1 1 SIM_BAR3_DRIFT 0.000000000000000000 9
1 1 SIM_BAR3_FREEZE 0 2
1 1 SIM_BAR3_GLITCH 0.000000000000000000 9
1 1 SIM_BAR3_RND 0.200000002980232239 9
1 1 SIM_BAR3_WCF_BAK 0.000000000000000000 9
1 1 SIM_BAR3_WCF_FWD 0.000000000000000000 9
1 1 SIM_BAR3_WCF_LFT 0.000000000000000000 9
1 1 SIM_BAR3_WCF_RGT 0.000000000000000000 9
1 1 SIM_BARO_COUNT 2 2
1 1 SIM_BARO_DELAY 0 4
1 1 SIM_BARO_DISABLE 0 2
1 1 SIM_BARO_DRIFT 0.000000000000000000 9
1 1 SIM_BARO_FREEZE 0 2
1 1 SIM_BARO_GLITCH 0.000000000000000000 9
1 1 SIM_BARO_RND 0.000000000000000000 9
1 1 SIM_BARO_WCF_BAK 0.000000000000000000 9
1 1 SIM_BARO_WCF_FWD 0.000000000000000000 9
1 1 SIM_BARO_WCF_LFT 0.000000000000000000 9
1 1 SIM_BARO_WCF_RGT 0.000000000000000000 9
1 1 SIM_BATT_CAP_AH 0.000000000000000000 9
1 1 SIM_BATT_VOLTAGE 12.600000381469726563 9
1 1 SIM_BAUDLIMIT_EN 0 2
1 1 SIM_BZ_ENABLE 0 2
1 1 SIM_BZ_PIN 0 2
1 1 SIM_DRIFT_SPEED 0.050000000745058060 9
1 1 SIM_DRIFT_TIME 5.000000000000000000 9
1 1 SIM_EFI_TYPE 0 2
1 1 SIM_ENGINE_FAIL 0 2
1 1 SIM_ENGINE_MUL 1.000000000000000000 9
1 1 SIM_FLOAT_EXCEPT 1 2
1 1 SIM_FLOW_DELAY 0 2
1 1 SIM_FLOW_ENABLE 0 2
1 1 SIM_FLOW_POS_X 0.000000000000000000 9
1 1 SIM_FLOW_POS_Y 0.000000000000000000 9
1 1 SIM_FLOW_POS_Z 0.000000000000000000 9
1 1 SIM_FLOW_RATE 10 4
1 1 SIM_FLOW_RND 0.050000000745058060 9
1 1 SIM_GND_BEHAV -1 2
1 1 SIM_GPS2_ACC 0.300000011920928955 9
1 1 SIM_GPS2_ALT_OFS 0 4
1 1 SIM_GPS2_BYTELOS 0.000000000000000000 9
1 1 SIM_GPS2_DELAY 1 2
1 1 SIM_GPS2_DISABLE 1 2
1 1 SIM_GPS2_DRFTALT 0.000000000000000000 9
1 1 SIM_GPS2_GLTCH_X 0.000000000000000000 9
1 1 SIM_GPS2_GLTCH_Y 0.000000000000000000 9
1 1 SIM_GPS2_GLTCH_Z 0.000000000000000000 9
1 1 SIM_GPS2_HDG 0 2
1 1 SIM_GPS2_HZ 5 2
1 1 SIM_GPS2_LCKTIME 0 4
1 1 SIM_GPS2_NOISE 0.000000000000000000 9
1 1 SIM_GPS2_NUMSATS 10 2
1 1 SIM_GPS2_POS_X 0.000000000000000000 9
1 1 SIM_GPS2_POS_Y 0.000000000000000000 9
1 1 SIM_GPS2_POS_Z 0.000000000000000000 9
1 1 SIM_GPS2_TYPE 1 2
1 1 SIM_GPS2_VERR_X 0.000000000000000000 9
1 1 SIM_GPS2_VERR_Y 0.000000000000000000 9
1 1 SIM_GPS2_VERR_Z 0.000000000000000000 9
1 1 SIM_GPS_ACC 0.300000011920928955 9
1 1 SIM_GPS_ALT_OFS 0 4
1 1 SIM_GPS_BYTELOSS 0.000000000000000000 9
1 1 SIM_GPS_DELAY 1 2
1 1 SIM_GPS_DISABLE 0 2
1 1 SIM_GPS_DRIFTALT 0.000000000000000000 9
1 1 SIM_GPS_GLITCH_X 0.000000000000000000 9
1 1 SIM_GPS_GLITCH_Y 0.000000000000000000 9
1 1 SIM_GPS_GLITCH_Z 0.000000000000000000 9
1 1 SIM_GPS_HDG 0 2
1 1 SIM_GPS_HZ 5 2
1 1 SIM_GPS_LOCKTIME 0 4
1 1 SIM_GPS_NOISE 0.000000000000000000 9
1 1 SIM_GPS_NUMSATS 10 2
1 1 SIM_GPS_POS_X 0.000000000000000000 9
1 1 SIM_GPS_POS_Y 0.000000000000000000 9
1 1 SIM_GPS_POS_Z 0.000000000000000000 9
1 1 SIM_GPS_TYPE 1 2
1 1 SIM_GPS_VERR_X 0.000000000000000000 9
1 1 SIM_GPS_VERR_Y 0.000000000000000000 9
1 1 SIM_GPS_VERR_Z 0.000000000000000000 9
1 1 SIM_GRPE_ENABLE 0 2
1 1 SIM_GRPE_PIN -1 2
1 1 SIM_GRPS_ENABLE 0 2
1 1 SIM_GRPS_GRAB 2000 4
1 1 SIM_GRPS_PIN -1 2
1 1 SIM_GRPS_RELEASE 1000 4
1 1 SIM_GRPS_REVERSE 0 2
1 1 SIM_GYR1_RND 0.000000000000000000 9
1 1 SIM_GYR1_SCALE_X 0.000000000000000000 9
1 1 SIM_GYR1_SCALE_Y 0.000000000000000000 9
1 1 SIM_GYR1_SCALE_Z 0.000000000000000000 9
1 1 SIM_GYR2_RND 0.000000000000000000 9
1 1 SIM_GYR2_SCALE_X 0.000000000000000000 9
1 1 SIM_GYR2_SCALE_Y 0.000000000000000000 9
1 1 SIM_GYR2_SCALE_Z 0.000000000000000000 9
1 1 SIM_GYR3_RND 0.000000000000000000 9
1 1 SIM_GYR3_SCALE_X 0.000000000000000000 9
1 1 SIM_GYR3_SCALE_Y 0.000000000000000000 9
1 1 SIM_GYR3_SCALE_Z 0.000000000000000000 9
1 1 SIM_GYR_FAIL_MSK 0 2
1 1 SIM_IE24_ENABLE 0 2
1 1 SIM_IE24_ERROR 0 6
1 1 SIM_IE24_STATE -1 2
1 1 SIM_IMUT1_ENABLE 0 2
1 1 SIM_IMUT2_ENABLE 0 2
1 1 SIM_IMUT3_ENABLE 0 2
1 1 SIM_IMUT_END 45.000000000000000000 9
1 1 SIM_IMUT_FIXED 0.000000000000000000 9
1 1 SIM_IMUT_START 25.000000000000000000 9
1 1 SIM_IMUT_TCONST 300.000000000000000000 9
1 1 SIM_IMU_COUNT 2 2
1 1 SIM_IMU_POS_X 0.000000000000000000 9
1 1 SIM_IMU_POS_Y 0.000000000000000000 9
1 1 SIM_IMU_POS_Z 0.000000000000000000 9
1 1 SIM_INS_THR_MIN 0.100000001490116119 9
1 1 SIM_LED_LAYOUT 0 2
1 1 SIM_LOOP_DELAY 0 6
1 1 SIM_MAG1_DEVID 97539 6
1 1 SIM_MAG1_FAIL 0 2
1 1 SIM_MAG1_SCALING 1.000000000000000000 9
1 1 SIM_MAG2_DEVID 131874 6
1 1 SIM_MAG2_DIA_X 0.000000000000000000 9
1 1 SIM_MAG2_DIA_Y 0.000000000000000000 9
1 1 SIM_MAG2_DIA_Z 0.000000000000000000 9
1 1 SIM_MAG2_FAIL 0 2
1 1 SIM_MAG2_ODI_X 0.000000000000000000 9
1 1 SIM_MAG2_ODI_Y 0.000000000000000000 9
1 1 SIM_MAG2_ODI_Z 0.000000000000000000 9
1 1 SIM_MAG2_OFS_X 5.000000000000000000 9
1 1 SIM_MAG2_OFS_Y 13.000000000000000000 9
1 1 SIM_MAG2_OFS_Z -18.000000000000000000 9
1 1 SIM_MAG2_ORIENT 0 2
1 1 SIM_MAG2_SCALING 1.000000000000000000 9
1 1 SIM_MAG3_DEVID 263178 6
1 1 SIM_MAG3_DIA_X 0.000000000000000000 9
1 1 SIM_MAG3_DIA_Y 0.000000000000000000 9
1 1 SIM_MAG3_DIA_Z 0.000000000000000000 9
1 1 SIM_MAG3_FAIL 0 2
1 1 SIM_MAG3_ODI_X 0.000000000000000000 9
1 1 SIM_MAG3_ODI_Y 0.000000000000000000 9
1 1 SIM_MAG3_ODI_Z 0.000000000000000000 9
1 1 SIM_MAG3_OFS_X 5.000000000000000000 9
1 1 SIM_MAG3_OFS_Y 13.000000000000000000 9
1 1 SIM_MAG3_OFS_Z -18.000000000000000000 9
1 1 SIM_MAG3_ORIENT 0 2
1 1 SIM_MAG3_SCALING 1.000000000000000000 9
1 1 SIM_MAG4_DEVID 97283 6
1 1 SIM_MAG5_DEVID 97795 6
1 1 SIM_MAG6_DEVID 98051 6
1 1 SIM_MAG7_DEVID 0 6
1 1 SIM_MAG8_DEVID 0 6
1 1 SIM_MAG_ALY_HGT 1.000000000000000000 9
1 1 SIM_MAG_ALY_X 0.000000000000000000 9
1 1 SIM_MAG_ALY_Y 0.000000000000000000 9
1 1 SIM_MAG_ALY_Z 0.000000000000000000 9
1 1 SIM_MAG_DELAY 0 4
1 1 SIM_MAG_DIA_X 0.000000000000000000 9
1 1 SIM_MAG_DIA_Y 0.000000000000000000 9
1 1 SIM_MAG_DIA_Z 0.000000000000000000 9
1 1 SIM_MAG_MOT_X 0.000000000000000000 9
1 1 SIM_MAG_MOT_Y 0.000000000000000000 9
1 1 SIM_MAG_MOT_Z 0.000000000000000000 9
1 1 SIM_MAG_ODI_X 0.000000000000000000 9
1 1 SIM_MAG_ODI_Y 0.000000000000000000 9
1 1 SIM_MAG_ODI_Z 0.000000000000000000 9
1 1 SIM_MAG_OFS_X 5.000000000000000000 9
1 1 SIM_MAG_OFS_Y 13.000000000000000000 9
1 1 SIM_MAG_OFS_Z -18.000000000000000000 9
1 1 SIM_MAG_ORIENT 0 2
1 1 SIM_MAG_RND 0.000000000000000000 9
1 1 SIM_ODOM_ENABLE 0 2
1 1 SIM_OPOS_ALT 584.000000000000000000 9
1 1 SIM_OPOS_HDG 353.000000000000000000 9
1 1 SIM_OPOS_LAT -35.363262176513671875 9
1 1 SIM_OPOS_LNG 149.165237426757812500 9
1 1 SIM_PARA_ENABLE 0 2
1 1 SIM_PARA_PIN -1 2
1 1 SIM_PIN_MASK 0 4
1 1 SIM_PLD_ALT_LMT 15.000000000000000000 9
1 1 SIM_PLD_DIST_LMT 10.000000000000000000 9
1 1 SIM_PLD_ENABLE 0 2
1 1 SIM_PLD_HEIGHT 0.000000000000000000 9
1 1 SIM_PLD_LAT 0.000000000000000000 9
1 1 SIM_PLD_LON 0.000000000000000000 9
1 1 SIM_PLD_RATE 100 6
1 1 SIM_PLD_TYPE 0 2
1 1 SIM_PLD_YAW 0 4
1 1 SIM_RATE_HZ 1200 4
1 1 SIM_RC_CHANCOUNT 16 2
1 1 SIM_RC_FAIL 0 2
1 1 SIM_RICH_CTRL -1 2
1 1 SIM_RICH_ENABLE 0 2
1 1 SIM_SAFETY_STATE 0 2
1 1 SIM_SERVO_SPEED 0.140000000596046448 9
1 1 SIM_SHIP_DSIZE 10.000000000000000000 9
1 1 SIM_SHIP_ENABLE 0 2
1 1 SIM_SHIP_PSIZE 1000.000000000000000000 9
1 1 SIM_SHIP_SPEED 3.000000000000000000 9
1 1 SIM_SHIP_SYSID 17 2
1 1 SIM_SHOVE_TIME 0 6
1 1 SIM_SHOVE_X 0.000000000000000000 9
1 1 SIM_SHOVE_Y 0.000000000000000000 9
1 1 SIM_SHOVE_Z 0.000000000000000000 9
1 1 SIM_SONAR_GLITCH 0.000000000000000000 9
1 1 SIM_SONAR_POS_X 0.000000000000000000 9
1 1 SIM_SONAR_POS_Y 0.000000000000000000 9
1 1 SIM_SONAR_POS_Z 0.000000000000000000 9
1 1 SIM_SONAR_RND 0.000000000000000000 9
1 1 SIM_SONAR_SCALE 10.000000000000000000 9
1 1 SIM_SPEEDUP 1.000000000000000000 9
1 1 SIM_SPR_ENABLE 0 2
1 1 SIM_SPR_PUMP -1 2
1 1 SIM_SPR_SPIN -1 2
1 1 SIM_TA_ENABLE 1 2
1 1 SIM_TEMP_BFACTOR 0.000000000000000000 9
1 1 SIM_TEMP_FLIGHT 35.000000000000000000 9
1 1 SIM_TEMP_START 25.000000000000000000 9
1 1 SIM_TEMP_TCONST 30.000000000000000000 9
1 1 SIM_TERRAIN 1 2
1 1 SIM_THML_SCENARI 0 2
1 1 SIM_TIDE_DIR 0.000000000000000000 9
1 1 SIM_TIDE_SPEED 0.000000000000000000 9
1 1 SIM_TWIST_TIME 0 6
1 1 SIM_TWIST_X 0.000000000000000000 9
1 1 SIM_TWIST_Y 0.000000000000000000 9
1 1 SIM_TWIST_Z 0.000000000000000000 9
1 1 SIM_VIB_FREQ_X 0.000000000000000000 9
1 1 SIM_VIB_FREQ_Y 0.000000000000000000 9
1 1 SIM_VIB_FREQ_Z 0.000000000000000000 9
1 1 SIM_VIB_MOT_MAX 0.000000000000000000 9
1 1 SIM_VIB_MOT_MULT 1.000000000000000000 9
1 1 SIM_VICON_FAIL 0 2
1 1 SIM_VICON_GLIT_X 0.000000000000000000 9
1 1 SIM_VICON_GLIT_Y 0.000000000000000000 9
1 1 SIM_VICON_GLIT_Z 0.000000000000000000 9
1 1 SIM_VICON_POS_X 0.000000000000000000 9
1 1 SIM_VICON_POS_Y 0.000000000000000000 9
1 1 SIM_VICON_POS_Z 0.000000000000000000 9
1 1 SIM_VICON_TMASK 3 2
1 1 SIM_VICON_VGLI_X 0.000000000000000000 9
1 1 SIM_VICON_VGLI_Y 0.000000000000000000 9
1 1 SIM_VICON_VGLI_Z 0.000000000000000000 9
1 1 SIM_VICON_YAW 0 4
1 1 SIM_VICON_YAWERR 0 4
1 1 SIM_WAVE_AMP 0.500000000000000000 9
1 1 SIM_WAVE_DIR 0.000000000000000000 9
1 1 SIM_WAVE_ENABLE 0 2
1 1 SIM_WAVE_LENGTH 10.000000000000000000 9
1 1 SIM_WAVE_SPEED 0.500000000000000000 9
1 1 SIM_WIND_DELAY 0 4
1 1 SIM_WIND_DIR 180.000000000000000000 9
1 1 SIM_WIND_DIR_Z 0.000000000000000000 9
1 1 SIM_WIND_SPD 0.000000000000000000 9
1 1 SIM_WIND_T 0 2
1 1 SIM_WIND_TURB 0.000000000000000000 9
1 1 SIM_WIND_T_ALT 60.000000000000000000 9
1 1 SIM_WIND_T_COEF 0.009999999776482582 9
1 1 SIM_WOW_PIN -1 2
1 1 SPRAY_ENABLE 0 2
1 1 SR0_ADSB 30 4
1 1 SR0_EXTRA1 30 4
1 1 SR0_EXTRA2 30 4
1 1 SR0_EXTRA3 30 4
1 1 SR0_EXT_STAT 30 4
1 1 SR0_PARAMS 0 4
1 1 SR0_POSITION 30 4
1 1 SR0_RAW_CTRL 30 4
1 1 SR0_RAW_SENS 30 4
1 1 SR0_RC_CHAN 30 4
1 1 SR1_ADSB 0 4
1 1 SR1_EXTRA1 0 4
1 1 SR1_EXTRA2 0 4
1 1 SR1_EXTRA3 0 4
1 1 SR1_EXT_STAT 0 4
1 1 SR1_PARAMS 0 4
1 1 SR1_POSITION 0 4
1 1 SR1_RAW_CTRL 0 4
1 1 SR1_RAW_SENS 0 4
1 1 SR1_RC_CHAN 0 4
1 1 SR2_ADSB 0 4
1 1 SR2_EXTRA1 0 4
1 1 SR2_EXTRA2 0 4
1 1 SR2_EXTRA3 0 4
1 1 SR2_EXT_STAT 0 4
1 1 SR2_PARAMS 0 4
1 1 SR2_POSITION 0 4
1 1 SR2_RAW_CTRL 0 4
1 1 SR2_RAW_SENS 0 4
1 1 SR2_RC_CHAN 0 4
1 1 SR3_ADSB 0 4
1 1 SR3_EXTRA1 0 4
1 1 SR3_EXTRA2 0 4
1 1 SR3_EXTRA3 0 4
1 1 SR3_EXT_STAT 0 4
1 1 SR3_PARAMS 0 4
1 1 SR3_POSITION 0 4
1 1 SR3_RAW_CTRL 0 4
1 1 SR3_RAW_SENS 0 4
1 1 SR3_RC_CHAN 0 4
1 1 SR4_ADSB 0 4
1 1 SR4_EXTRA1 0 4
1 1 SR4_EXTRA2 0 4
1 1 SR4_EXTRA3 0 4
1 1 SR4_EXT_STAT 0 4
1 1 SR4_PARAMS 0 4
1 1 SR4_POSITION 0 4
1 1 SR4_RAW_CTRL 0 4
1 1 SR4_RAW_SENS 0 4
1 1 SR4_RC_CHAN 0 4
1 1 SR5_ADSB 0 4
1 1 SR5_EXTRA1 0 4
1 1 SR5_EXTRA2 0 4
1 1 SR5_EXTRA3 0 4
1 1 SR5_EXT_STAT 0 4
1 1 SR5_PARAMS 0 4
1 1 SR5_POSITION 0 4
1 1 SR5_RAW_CTRL 0 4
1 1 SR5_RAW_SENS 0 4
1 1 SR5_RC_CHAN 0 4
1 1 SR6_ADSB 0 4
1 1 SR6_EXTRA1 0 4
1 1 SR6_EXTRA2 0 4
1 1 SR6_EXTRA3 0 4
1 1 SR6_EXT_STAT 0 4
1 1 SR6_PARAMS 0 4
1 1 SR6_POSITION 0 4
1 1 SR6_RAW_CTRL 0 4
1 1 SR6_RAW_SENS 0 4
1 1 SR6_RC_CHAN 0 4
1 1 SRTL_ACCURACY 2.000000000000000000 9
1 1 SRTL_POINTS 300 4
1 1 STAT_BOOTCNT 67 4
1 1 STAT_FLTTIME 257 6
1 1 STAT_RESET 160562576 6
1 1 STAT_RUNTIME 3691302 6
1 1 SUPER_SIMPLE 0 2
1 1 SYSID_ENFORCE 0 2
1 1 SYSID_MYGCS 255 4
1 1 SYSID_THISMAV 1 4
1 1 TCAL_ENABLED 0 2
1 1 TELEM_DELAY 0 2
1 1 TERRAIN_ENABLE 1 2
1 1 TERRAIN_OPTIONS 0 4
1 1 TERRAIN_SPACING 100 4
1 1 THROW_MOT_START 0 2
1 1 THROW_NEXTMODE 18 2
1 1 THROW_TYPE 0 2
1 1 THR_DZ 100 4
1 1 TUNE 0 2
1 1 TUNE_MAX 0.000000000000000000 9
1 1 TUNE_MIN 0.000000000000000000 9
1 1 VISO_DELAY_MS 10 4
1 1 VISO_ORIENT 0 2
1 1 VISO_POS_M_NSE 0.200000002980232239 9
1 1 VISO_POS_X 0.000000000000000000 9
1 1 VISO_POS_Y 0.000000000000000000 9
1 1 VISO_POS_Z 0.000000000000000000 9
1 1 VISO_SCALE 1.000000000000000000 9
1 1 VISO_TYPE 1 2
1 1 VISO_VEL_M_NSE 0.100000001490116119 9
1 1 VISO_YAW_M_NSE 0.200000002980232239 9
1 1 VTX_ENABLE 0 2
1 1 WINCH_TYPE 0 2
1 1 WPNAV_ACCEL 50.000000000000000000 9
1 1 WPNAV_ACCEL_Z 50.000000000000000000 9
1 1 WPNAV_RADIUS 200.000000000000000000 9
1 1 WPNAV_RFND_USE 1 2
1 1 WPNAV_SPEED 500.000000000000000000 9
1 1 WPNAV_SPEED_DN 150.000000000000000000 9
1 1 WPNAV_SPEED_UP 250.000000000000000000 9
1 1 WP_NAVALT_MIN 0.000000000000000000 9
1 1 WP_YAW_BEHAVIOR 2 2
1 1 ZIGZ_AUTO_ENABLE 0 2
romaster93
(woosung cho)
February 9, 2021, 10:10am
4
I would like to send you my simulation video. However, I cannot upload videos here because of the oversize. Is there any way?
You need to upload the video somewhere, and post a link here.
romaster93
(woosung cho)
February 9, 2021, 11:07am
6
and
this.
and now i try run a orb slam2 using ekf3, but ekf3 refusing origin error is occur.
@rmackay9 do you have any ideas?
rmackay9
(rmackay9)
February 10, 2021, 12:01am
8
A onboard log file would be best of course. Videos are ok but they don’t really give a lot of detail of what is going on inside AP.
AP will refuse setting of the origin if the GPS is enabled. I suspect some of the EK3_SRCx parameters haven’t been set correctly. Probably some of them are still “3” which is for GPS.
We should probably allow the EKF3 to accept an origin even if GPS is configured because the vehicle may initially be somewhere that it cannot get a GPS fix.
By the way, the setup should be similar to the setup of the T265 which is described here on the wiki . You probably want to keep VISO_TYPE = 1 instead of “2” which has some specific features for the T265.
It might also be good to drop into the “vision-projects” channel in discord (see link here )
romaster93
(woosung cho)
February 10, 2021, 4:07am
9
Can I leave questions freely on the discord channel?
rmackay9
(rmackay9)
February 10, 2021, 4:26am
10
@romaster93 ,
yes, especially in the vision-projects chat we try to help users setup the system because it’s still fairly new.
