I have been struggling with getting GPS Yaw to provide heading for a week with no luck. I am running a Cube Blue with ArduCopter firmware V 4.5.1 (Function.txt file indicates moving baseline is included), and two HerePros which are running the latest firmware, V 1.13.BF5E50D8 and are HW version 4.13.
The Ardu parameters have been set per the recommendations in the HerePro Manual and in the Ardupilot.org Docs GPS for Yaw (aka Moving Baseline) - Copter documentation. The HerePros are 0.567 meters apart, with the 1 unit Y-axis position set to -0.244 m and the #2 unit’s Y-axis position set to 0.323 m in the Ardupilot parameters.
The gpsyaw and gpsyaw2 values are always 0, and do not change when the test setup is rotated. The PFD window indicates GPS1: 3D Fix and GPS2: rtk Fixed.
The attached zip file includes the parameter files for the Cube and the two HerePros.
Ardupilot Info.zip (6.7 KB)
Has anyone been able to get GPS Yaw to function without writing custom code?
