I need to check again the basic tuning, as acro mode is not as good as some weeks ago.
Severals issues in acro mode :
Throttle issue : sometime if rover are stopped, even If I put full trottle, rover don’t want to moove…
Steering issue : when runing, steering seem to be ok, but sometime rover slow down / stop (I don’t reduce the throttle stick) and sometime even if the steering stick it’s full right, sometime I can see that the rover want to turn to the left…
Where can be the issue for the rover that don’t want to start even If I put 100% throttle on my stick ?
And what can be the cause of the steering issue in acro mode (at stop or very low speed, rover want to turn even if the stick are full right) ?
It’s all linked to PID issue or I need to search also in othe place ?
Hi mate, I’m also trying to adjust the PID’s with a very large rover and it’s a little hell, when you get a small advance another one gets out of adjustment and you can’t get everything to go well like a small rover. In my case, now the direction is going a bit well, but the speed cannot be smooth and it speeds up or slows down (decelerates) when it arrives at or leaves a waypoint.
