Installed latest MP and 3.2, now when I go to terminal in MP, when it connects, it looks like it is displaying lines of code. It starts with something about the barometer and then lines and lines of code. Did the erase, reset but that did no good. Went back to 3.1.5 and all works again. any ideas?
@devveldogg,
I believe that the CLI function in 3.2 may have been removed due to code size limitation.
Regards,
TCIII GM
CLI is not available anymore. You can do all with MP now.
Yes in 3.2 you must use Mavlink to down load files and ect. So go to the HUD screen and connect via USB (mavlink) Then Data logs down load and ect.
APM 2.6 3.2
Thanks all. Looks like I missed that.
