First, you do not have a category for ArduRemoteID.
This is on Fedora38.
Now I am trying to follow the instructions at:
I have already installed arduino stuff with flatpak, so started with the git clone line. I got to ./scripts/regen_headers.sh and got errors which I attach below. Please help me figure out what is needed.
expanding com.hex.equipment.flow.Measurement
expanding com.hobbywing.esc.SelfTest
Caught exception! ‘dict’ object has no attribute ‘unknownScriptName’
Traceback (most recent call last):
File “/home/rgm/Arduino/arduremoteid/modules/dronecan_dsdlc/dronecan_dsdlc.py”, line 197, in
assert not buildlist-builtlist, “%s not built” % (buildlist-builtlist,)
AssertionError: {‘uavcan.protocol.file.GetInfo’, ‘com.hex.equipment.flow.Measurement’, ‘dronecan.sensors.rc.RCInput’, ‘uavcan.protocol.file.GetDirectoryEntryInfo’, ‘uavcan.equipment.indication.LightsCommand’, ‘dronecan.remoteid.SelfID’, ‘uavcan.tunnel.Protocol’, ‘uavcan.equipment.gnss.Fix’, ‘uavcan.equipment.camera_gimbal.Mode’, ‘uavcan.equipment.safety.ArmingStatus’, ‘uavcan.equipment.power.CircuitStatus’, ‘uavcan.equipment.gnss.ECEFPositionVelocity’, ‘uavcan.equipment.ice.reciprocating.Status’, ‘uavcan.protocol.file.Delete’, ‘uavcan.protocol.enumeration.Begin’, ‘uavcan.tunnel.Call’, ‘com.hobbywing.esc.SetID’, ‘uavcan.protocol.dynamic_node_id.server.Entry’, ‘dronecan.remoteid.System’, ‘dronecan.remoteid.ArmStatus’, ‘uavcan.equipment.camera_gimbal.AngularCommand’, ‘com.himark.servo.ServoCmd’, ‘dronecan.remoteid.SecureCommand’, ‘uavcan.equipment.air_data.IndicatedAirspeed’, ‘uavcan.protocol.DataTypeKind’, ‘uavcan.equipment.ahrs.MagneticFieldStrength2’, ‘uavcan.protocol.debug.KeyValue’, ‘uavcan.protocol.dynamic_node_id.server.Discovery’, ‘com.volz.servo.ActuatorStatus’, ‘uavcan.protocol.file.BeginFirmwareUpdate’, ‘uavcan.equipment.power.BatteryInfo’, ‘uavcan.Timestamp’, ‘uavcan.equipment.device.Temperature’, ‘com.hobbywing.esc.RawCommand’, ‘uavcan.equipment.ahrs.RawIMU’, ‘uavcan.protocol.GetNodeInfo’, ‘uavcan.protocol.param.ExecuteOpcode’, ‘com.hobbywing.esc.StatusMsg2’, ‘uavcan.equipment.gnss.Auxiliary’, ‘uavcan.protocol.dynamic_node_id.server.RequestVote’, ‘com.hobbywing.esc.SetLED’, ‘uavcan.equipment.ice.FuelTankStatus’, ‘uavcan.protocol.param.Empty’, ‘uavcan.protocol.debug.LogLevel’, ‘uavcan.protocol.dynamic_node_id.server.AppendEntries’, ‘uavcan.equipment.air_data.AngleOfAttack’, ‘uavcan.tunnel.Broadcast’, ‘uavcan.equipment.gnss.RTCMStream’, ‘uavcan.protocol.param.Value’, ‘uavcan.equipment.air_data.StaticTemperature’, ‘uavcan.equipment.hardpoint.Command’, ‘uavcan.equipment.range_sensor.Measurement’, ‘uavcan.protocol.dynamic_node_id.Allocation’, ‘uavcan.equipment.esc.Status’, ‘uavcan.equipment.actuator.Command’, ‘uavcan.protocol.debug.LogMessage’, ‘com.hobbywing.esc.SetAngle’, ‘uavcan.CoarseOrientation’, ‘uavcan.equipment.camera_gimbal.GEOPOICommand’, ‘dronecan.remoteid.Location’, ‘uavcan.equipment.power.PrimaryPowerSupplyStatus’, ‘uavcan.equipment.indication.SingleLightCommand’, ‘uavcan.equipment.actuator.Status’, ‘com.hobbywing.esc.SetThrottleSource’, ‘uavcan.protocol.GlobalTimeSync’, ‘uavcan.navigation.GlobalNavigationSolution’, ‘com.hobbywing.esc.SetBaud’, ‘uavcan.equipment.ahrs.Solution’, ‘uavcan.equipment.ice.reciprocating.CylinderStatus’, ‘uavcan.protocol.GetTransportStats’, ‘uavcan.protocol.enumeration.Indication’, ‘uavcan.equipment.esc.RawCommand’, ‘com.hobbywing.esc.GetMajorConfig’, ‘uavcan.protocol.RestartNode’, ‘uavcan.equipment.air_data.TrueAirspeed’, ‘uavcan.protocol.param.NumericValue’, ‘uavcan.equipment.indication.BeepCommand’, ‘uavcan.protocol.file.Write’, ‘com.hobbywing.esc.SetDirection’, ‘uavcan.equipment.hardpoint.Status’, ‘uavcan.protocol.param.GetSet’, ‘uavcan.equipment.esc.RPMCommand’, ‘uavcan.equipment.ahrs.MagneticFieldStrength’, ‘uavcan.protocol.file.Path’, ‘uavcan.protocol.AccessCommandShell’, ‘uavcan.protocol.GetDataTypeInfo’, ‘com.hobbywing.esc.SelfTest’, ‘uavcan.protocol.Panic’, ‘uavcan.equipment.gnss.Fix2’, ‘com.hobbywing.esc.StatusMsg3’, ‘uavcan.protocol.HardwareVersion’, ‘com.hobbywing.esc.StatusMsg1’, ‘com.hobbywing.esc.GetEscID’, ‘uavcan.equipment.air_data.RawAirData’, ‘dronecan.remoteid.BasicID’, ‘uavcan.protocol.NodeStatus’, ‘com.hobbywing.esc.GetMaintenanceInformation’, ‘com.hobbywing.esc.SetReportingFrequency’, ‘uavcan.tunnel.SerialConfig’, ‘uavcan.protocol.SoftwareVersion’, ‘uavcan.protocol.CANIfaceStats’, ‘uavcan.protocol.file.Error’, ‘uavcan.equipment.air_data.StaticPressure’, ‘uavcan.protocol.file.EntryType’, ‘uavcan.equipment.air_data.Sideslip’, ‘dronecan.sensors.hygrometer.Hygrometer’, ‘com.himark.servo.ServoInfo’, ‘uavcan.equipment.camera_gimbal.Status’, ‘uavcan.protocol.file.Read’, ‘uavcan.equipment.indication.RGB565’, ‘dronecan.remoteid.OperatorID’, ‘uavcan.equipment.actuator.ArrayCommand’} not built
./scripts/regen_headers.sh: line 16: cd: libraries/DroneCAN_generated: No such file or directory
[rgm@lx140e arduremoteid]$
