Hi all,
I bought a Pixhawk and mounted it on an Y6, connected it to mission planner, flashed it, configured it with the param file, calibrated the magnetometer and accelerometers, set up my radio and calibrated it.
Now I want to start the motors to see if they turn on the correct side but I can’t find how to arm or I can’t find what error prevents it to arm.
Let’s say I connect it to mission planner to have more infos, I turn on my radio, power the pixhawk, get that little music which says it started up.
Now it shows DISARMED in red in mission planner and the big LED flashes two times yellow repeatedly, the act LED flashes blue, the B/E LED doesn’t flashes and Pwr LED is solid green and the safety button flashes red.
If I am in loiter mode I wait to have GPS fix, doesn’t change anything compared to be in acro mode.
Now if I press the safety button, it becomes solid red and the motors make a little music, the screen in mission planner still shows disarmed and the big led still flashes two times yellow repeatedly.
If I put the trottle on the low right corner, nothing happens, neither low left.
Could someone please give me some hint to find the problem because I read all the manuals I found etc, I didn’t find some way to know what error the double flashing yellow led shows.
Btw, the power module gives coherent datas, like 15,24V (4S battery not full) and current consumption like 0,1A
Thank you very much to the one who’ll help me to get my Y6 flying.
