I am testing 2 telemetry connections:
1: LTE using UAVCAST, connected to Serial 1
2: Short range 100mW, 915Mhz, connected to serial 4
I power up the aircraft, start mission planner and wait for UDP to automatically connect.
I can then give commands to the pixhawk. So this is working. Then i right click on the top bar, choose connection options and select Com5, the baudrate and connect. I can now give commands to the pixhawk as well.
I can now switch between the 2 connections and receive the telemetry.
But… i cannot give commends through the UDP connection anymore. The screen freezes and after a while i get Error, no response from UAV.
Through the com5 (the second connection) is still working.
Even when i disconnect the 2nd telemetry, it still doesn’t work anymore.
Please help.
