I’ve received a couple of new Orange Cubes and I went to change the firmware (they had ArduPlane on them initially but I needed ArduCopter) but I’m having a lot of issues. I’ve had many boards before and this is the first time I’m having this issue.
First problem is when I try to do this on Mission Planner, it says ‘Failed to discover board id’.
A few notes/comments regarding things I’ve checked:
- The initial ArduPlane did connect properly
- The COM port has the proper driver and does show Cube Orange Mavlink
- I tried on QGroundControl and it does connect and did change the firmware but that leads me to my next problem
Second problem is that now that I’ve updated the firmware on QGroundControl, I cannot seem to connect to Mission Planner. It’ll connect like normal but then gets stuck on ‘Getting Params’ for a never ending amount of time. This is a wired USB connection and the wire itself does work. Note that it does still connect in QGroundControl but I want to use Mission Planner as that is what I am used to.
Does anyone have any advice or experience with this problem? Thank you
