The MP version on my Windows 7 laptop (32-bit, not 64-bit) is not update, at 1.3.40 build 1.1.6105.13696. After updating, I got an error message,attached, saying Remote Server returned an error.
Before updating, I have the laptop Windows 7 updated at Microsoft website.
Thanks Michael. I solved the issue by reinstalling from msi.
Being the main developer of MP, you should be the best person to help me with the other questions on this software :–
I accidentally checked the LOG_BITMASK box under “Fav” column in Full Param list… As a result, this param moved to the top of the param list. How can I move it down so it is listed in alphabetical order ?
I have 3 laptops with latest MP version (1.3.61) installed. However, I got “Payload Control” tab underneath HUD in only 2 of my 3 laptops, but missing it in the 3rd one. I tried re-install both .net framework 4.6.1 and msi, and reboot the 3rd laptop. But this did not help.
The 2 laptops with “Payload Control” appearing are :
a) Toshiba Satellite running on Windows 7 (32-bit OS)
b) Acer running on Windows 10 (64-bit OS)
The laptop without “Payload Control” appearing is HP running Windows 7 (64-bit OS). During re-installing msi, I was prompted to choose “repair” in the installation setting.
Any light you can shed to troubleshoot ?
By the way, I searched “Payload Control” in MP serach box with nothing returned. Any description on this ?
But for moving the param, I tried unchecking the fav before, there was no change.
Just now, I tried again unchecking the fav, there is no change in the screen. I then click “disconnect” and “Connect” again, not only the param still stays at the top, the check mark re-appears. Weird.
