Regarding the “save waypoint” feature. It’s not working for me, but perhaps I simply don’t understand how to use it. I have assigned a button on my transmitter to the purpose, and set the RCxx_option = 7 for the appropriate channel. I have some solid feedback that it is functioning properly, as I get an info message on the radio via telemetry stating “SaveWaypoint HIGH” (and “SaveWaypoint LOW”) when I press (and release) the button. That seems like pretty solid confirmation.
Then I download the mission off of the FC, and it remains empty. Isn’t that where the saved waypoint shows up? Doesn’t it add it to the mission, and then we can download the mission from the FC to view the saved waypoint? If I’m doing everything properly I can save and upload a proper datalog, parameters, etc, but let’s start by finding out if I’m simply clueless here. thanks, Matt
Okay, I resolved my issue. The first time I had my transmitter set incorrectly; the second time I was trying to troubleshoot it on the bench, not realizing that it needs to be armed to function (thanks for quoting the appropriate code snippet, which clued me in). Thanks!
Rover :: I have the same setup with RC_7 set for waypoints - “Waypoint set high/low” shows up in the HUD and messages, and also when replaying the TLOG. But, when I try to save the waypoints from the .tlog file, no waypoints are found.
Was armed, and in manual mode.
LAT and LON are logged in the .tlog for positioning replay I assume. Would be fun to export the breadcrumbs. I tried it a couple of times, but got lost in crunching the .csv file of 14K records…
Would appreciate any thoughts - let me know if you need a snippet of the .tlog (31mb) or anything else to tshoot…cd
