Cannot graph telemetry logs
For many versions of MP, I have not been able to graph telemetry logs. I can load a log and “play” it, but I cannot graph telemetry logs under any circumstances. I cannot even open OLD log files that I once could graph.
When I transfer the log files to another computer, that computer will not graph the log files!
I’m running MP 1.3.56
I need to graph the log files!!!
When I try to graph a log file, I get an error pane that says -
System.NullReferenceException: Object reference not set to and instance of an object at MissionPlannerCurrent State.UpdateCurrentSettings…
Try Apmplanner2 , much faster and better for log analysis.
please upgrade to the latest MP.
MIchael,
I updated to 1.3.57 the graphing function still doesn’t work. All the
other functions are fine.
Charles Linquist
Check out my multirotor blog at http://calmultirotor.com
do you get an error? I don’t have enough info to check the issue
[Michael_Oborne] Michael_Oborne
https://discuss.ardupilot.org/u/michael_oborne
July 22
Below is a screenshot of the error. Let me know if you don’t get it.
the latest mp update 1.3.57 should fix this.
July 23
I updated to 1.3.57. Still doesn’t work.
Screen capture below:
Charles Linquist
can I get a copy of your log? are you running modified ArduPilot code?
No mods. Latest beta PixHawk code.
tlog file attached.
Charles Linquist
2018-07-21 15-21-02.zip (290 KB)
2018-07-21 15-21-02.tlog (561 KB)
I should mention that APM Planner DOES work.
Do you happen to have speech prompts turned on?
I think it might be a bad setting but not sure yet.
the reason I ask is because looking at the line numbers in your screenshot don’t match the code used to generate that release version.
I’ll try various things. But it doesn’t work on 3 different computers.
All have voice prompts turned on.
Charles Linquist
try turning voice prompts off, and see if that changes anything?
knowing this will at least pinpoint it to a single spot
Michael,
I don’t know if you got my earlier message. Turning off voice prompts
makes it work again!
Charles Linquist
perfect thanks, now I have somewhere to look for the cause
could you send me you config file it should be here
"C:\Users<username>\Documents\Mission Planner\config.xml"
I would just like to check what you have set
July 28
“C:\Users\Documents\Mission Planner\config.xml”
Visit Topic
https://discuss.ardupilot.org/t/cannot-graph-telemetry-logs/31121/17
or reply to this email to respond.
    In Reply To
[charles_linquist] charles_linquist
https://discuss.ardupilot.org/u/charles_linquist
July 28
Michael, I don’t know if you got my earlier message. Turning off voice
prompts makes it work again! Charles Linquist Check out my multirotor
Visit Topic
To unsubscribe from these emails, click here
https://discuss.ardupilot.org/email/unsubscribe/71ed6f61c1d2fda9a3d729444a3802e88c59336f7fe6b69cf37df46c5f9f5183.
config.zip (2.95 KB)
