I’m using the latest firmware and MWOSD GUI, and I cannot load the firmware. I can read and write to the board with the factory-installed firmware, but when I try to flash it, I get the attached message (see pic).
Thanks!!
Thanks!!
What is the error message? Not clear…
I put a video for min OSd sometime ago https://youtu.be/Gk4vapruKOI
Thanks for the reply. The error message is in the red box in the top left corner.
Yep, I’m using the latest build of the Windows GUI.
Ive used MWOSD in the past and never had a problem. For some reason it will not flash.
Try another GUI like this one.
If it allows u to flash then try the other soft afterwards.
Have you connected the DTR line between minimiosd and FTDI, needed for flashing?
That’s a good point. Make sure you have DTR and RTS pins connected.
It’s hooked up correctly. I’m at a complete loss. I contacted the developer of MWOSD to help troubleshoot it, but it’s not working. I’m going to try a different board and see what happens.
Thanks for all the help!
