I’m trying to add a widget to the Flightdata to view some data from the distance sensor. However I cannot open the flightdata class in design view. I can open every other class in design view though.
These are the errors associated.
** Could not load file or assembly ‘SkiaSharp, Version=1.60.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756’ or one of its dependencies. The system cannot find the file specified | Could not load file or assembly ‘SkiaSharp, Version=1.60.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756’ or one of its dependencies. The system cannot find the file specified **
**Could not load file or assembly ‘SkiaSharp, Version=1.60.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756’ or one of its dependencies. The system cannot find the file specified **
Hello @Michael_Oborne, since i have the same problem, could you be a bit more specific?
I tried downgrading to 1.60.0.0 but than i get a ton of different errors, so i guess you mean something else.
Would really appreciate a little help.
If somebody else figured this out can please tell me how you did it?
@Michael_Oborne did the following but still same error in flightdata design:
1 copied skiasharp.dll from installed MP folder to a folder where i have gacutil
2 went to folder where i have gacutil and skiasharp.dll and run gacutil -i skiasharp.dll from an admin prompt
3 skiasharp.dll was correctly registered
4 went to visual studio, opened solution and same problem in flightdata design
5 Skiasharp package i am using at the moment is 1.68.0
I probably do not understand what i have to do, could you please be a bit more specific about what needs to be done? I guess it’ll stay here for future reference and users if i can solve it.
Sorry to be a bit dumb on the issue.
Finally fixed, thank you. It has a been difficult to find the 1.60 dll, but once i found it gacutil solved the issue.
For anyone that could have same problem in future here is what i did:
Inside visual studio i went to nuget package manager
disinstalled skiasharp 1.68 and installed skiasharp 1.60 in order to create the 1.60 skiasharp.dll in my system
disinstalled skiasharp 1.60 and went back to skiasharp 1.68
searched skiasharp.dll in my system and made sure it was versio 1.60 looking in file details
searched for gacutil.exe in my system
started an administrator command prompt and run gacutil.exe -i skiasharp.dll
before running the utility i copied the 1.60 skiasharp.dll in the same folder as the gacutil.exe
After each disinstall and after each install, for peace of mind, i restarted both pc and VS.
Doing this fixed my problem in editing the flightdata.cs
If anyone needs it i can send them the 1.60 skiasharp.dll so that only the last 3 points need to be done.
Hopefully if someone else has same problem as me he can fix it in 5 minutes instead of weeks like me
