OldGazer
(OldGazer)
#1
I am running MP 1.3.72 Build 1.3.7463.24854.
Last night I got the Update Found pop-up.
Clicked Yes.
Got the following error message:
Update failed File downloaded does not match hash: Drivers/DriversCleanup.exe
Installing using the .MSI file works…
kalai1219
(Kalai1219)
#2
I got same issue then I downloaded from web directly and installed as normal installation method.
mjbunan
(Michael Nunan)
#3
I got the same error, - now it fails with error that file not found (being updated?)
mjbunan
(Michael Nunan)
#4
I tried installing the .msi version - fails to start
ill get this fixed, the download server often seems to break things
looks like your issue is a file failed to install, have you rebooted?
