Suddenly and randomly I cannot connect a Navio2 running ArduRover 4.0.0 to Mission Planner on a Windows 10 PC. Sometimes it connects and works perfectly. The next time I try to connect, it will not and I get this diagnostic:
I successfully connected once, then after several reboots and cold starts I no longer can connect.
Also did a ps -ef|grep ardu and it appears that the pi is sending the data out port 14550 on the correct IP address.
I also put the tcpdump sniffer on the wlan1 interface and see the UDP packets with the correct IP and port. I’m using an external USB wifi dongle and have the internal wifi shutdown.
I turned off the firewall and it still does not connect.
Go to HELP and check “show console window (restart)” and the bottom of the window. Then restart MP. However it seems a navio problem to me, and nothing to do with MP.
