Can we install compass board side ways on Arduplane?
Hi all,
Wondering if I can install my GY-273 compass board on the side of the fuselage , away from the electronics and current carrying wires, at 90 degrees instead of laying flat inside the fuselage at 0 degrees? Thanks.
if i remember well you can do it… but set also the yaw and calibrate it
Sure you can and the orientation parameter is set automatically by default (COMPASS_AUTO_ROT) when you run the calibration function.
Thanks. Yes I will be using the COMPASS_AUTO_ROT.
Cheers…
Hi @ninja_zx11
As mentioned by Dave the parameter:
works really well for me. The application of a vertically installed compass I have shown here:
Thanks VRquaeler.
This is exactly same I was thinking to install!!
