Hello
I am using the Cube Orange Plus FC and would like to ensure that the flight controller has a reliable backup power source.
I understand that the Power1 and Power2 ports are the primary sources for power redundancy. However, I am wondering if the Servo Rail (PWM Output Rail) can also act as a backup power source in case Power1 and Power2 fail.
Specifically, I would like to know:
- If I supply a stable 5V to the Servo Rail, will it keep the Cube Orange Plus FC running if Power1 and Power2 lose power?
- If yes, does the Cube Orange Plus have built-in support for automatic power failover to the Servo Rail?
- Are there any risks or limitations to using the Servo Rail as a backup power source?
I would appreciate any official documentation or technical insights regarding this topic.
Thank you!
