Can`t receive MSGs from Pixhawk4 to STM32?
Hi, i am new to MAVLink and PX4 so i decided to learn by creating little project.
I have Pixhawk4 and old STM32F411CEU6 microcontroller and i want to capture information with it.
Ofcource i read greate article by Juan Pedro López (MAVLink and Arduino: step by step). It answered to many of my questions, but still it does not work in my case…
PROBLEM:
In the end I want to control custom gimbal but for now it would be nice to just receive some simplest MSGs from Pixhawk4 in STM32F411CEU6 , as it was in the article. BUT i can not figure out why it does not work. It is not clear what exactly the problem is. All i see is that inpSerial always empty whitch means either i have a problem with STM32 or requesting messages.
The good news is that i can see Heartbeat in MissionPlaner.
MY CODE AND HARDWARE:
I write in Arduino IDE (settings for STM32 i fount in some article) and use FTDI arduino to display messages in Termit app .
#include <Arduino.h>
#include <SoftwareSerial.h>                             // http://arduino.cc/en/Reference/softwareSerial
#include <mavlink.h>
#define rxInp PA3
#define txInp PA2
#define rxOut PB7
#define txOut PB6
SoftwareSerial inpSerial(rxInp, txInp);                     //PX -> STM32
SoftwareSerial outSerial(rxOut, txOut);                     //STM32 ->
//------------------------------ MACROS -----------------------------
#define MAV_TYPE_GIMBAL 26       //temporary here
// Debug:
#define DEBUG_MODE
//---------------------------- VARIABLES ----------------------------
// Mavlink variables:
unsigned long previousMillisMAVLink   = 0;              // will store last time MAVLink was transmitted and listened
unsigned long nextIntervalMAVLink     = 1000;           // next interval to count
const int     c_num_hbs               = 60;             // № of heartbeats to wait before activating STREAMS from Pixhawk. 60 = one minute.
int           num_hbs_pasados         = c_num_hbs;
//Sets the data rate in bits per second
const int     c_connectionSpeed       = 57600;
//MAVLink
int           sysid                   = 1;                       ///< ID 1: id of plane (stm32 is planes` component)
int           compid                  = 158;                     ///< The component sending the message
int           type                    = MAV_TYPE_GIMBAL /*MAV_TYPE_FIXED_WING*/;         ///< Gimbal
// Define the system type, in this case an airplane -> on-board controller
uint8_t       system_type             = MAV_TYPE_GENERIC;
uint8_t       autopilot_type          = MAV_AUTOPILOT_INVALID;
uint8_t       system_mode             = MAV_MODE_PREFLIGHT;      ///< Booting up
uint32_t      custom_mode             = 0;                       ///< Custom mode, can be defined by user/adopter
uint8_t       system_state            = MAV_STATE_STANDBY;       ///< System ready for flight
void setup()
  pinMode(rxInp, INPUT);
  pinMode(txInp, OUTPUT);
  pinMode(rxOut, INPUT);
  pinMode(txOut, OUTPUT);
  inpSerial.begin(c_connectionSpeed);
  outSerial.begin(c_connectionSpeed);
void loop()
  // Initialize the required buffers
  mavlink_message_t msg;
  uint8_t buf[MAVLINK_MAX_PACKET_LEN];
  // Pack the message
  //mavlink_msg_heartbeat_pack(sysid,compid, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
  mavlink_msg_heartbeat_pack(1,0, &msg, type, autopilot_type, system_mode, custom_mode, system_state);  //OLD
  // Copy the message to the send buffer
  uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
  // Send the message with the standard UART send function
  // uart0_send might be named differently depending on
  // the individual microcontroller / library in use.
  unsigned long currentMillisMAVLink = millis();
  if (currentMillisMAVLink - previousMillisMAVLink >= nextIntervalMAVLink) {
    // Save the last time you changed the mode
    previousMillisMAVLink = currentMillisMAVLink;
    inpSerial.write(buf,len);
#ifdef DEBUG_MODE
    outSerial.println(" HB         [-----SENT-----]");
#endif
    num_hbs_pasados++;
    if(num_hbs_pasados>=c_num_hbs) {
      Mav_Request_Data();
      num_hbs_pasados=0;
  comm_receive();
//------------------------ Mav_Request_Data()------------------------
//  1 - Request from Pixhawk what DATA SETs STM32 wants;
//  2 - Request transmission rate.
void Mav_Request_Data()
// To be setup according to the needed information to be requested from the Pixhawk
  const int       maxStreams              = 2;
  const uint8_t   MAVStreams[maxStreams]  = {MAV_DATA_STREAM_ALL/*MAV_DATA_STREAM_EXTENDED_STATUS*//*, MAV_DATA_STREAM_EXTRA1*/};
  const uint16_t  MAVRates[maxStreams]    = {0x02/*, 0x05*/};            //data rate in Hz (times per second)
  for (int i=0; i < maxStreams; i++) {
    //Pack
    //v1
    mavlink_msg_request_data_stream_pack(2, 200, &msg, 1, 0, MAVStreams[i], MAVRates[i], 1);    //OLD
//    mavlink_msg_request_data_stream_pack(sysid, compid, &msg, 1, 0, MAVStreams[i], MAVRates[i], 1);
//    //v2
//    const uint16_t MAVStreamID= 0;    //HB
//    const uint32_t MAVRates = 511;
//    mavlink_msg_message_interval_pack(2, 200, &msg, MAVStreamID, MAVRates);
    //Send
#ifdef DEBUG_MODE
    outSerial.println(" MAVLink    [--REQUESTED!--].");
#endif
//-------------------------- comm_receive()--------------------------
// 1 - Focus on what messages we are interested in and how to decode them
void comm_receive()
#ifdef DEBUG_MODE
  //outSerial.println(" comm_receive() [open].");
#endif
  mavlink_status_t status;
  while(inpSerial.available()>0) {                  // PROBLEM!!!!!!
    uint8_t c = inpSerial.read();
#ifdef DEBUG_MODE
      outSerial.println("----while works----");
#endif
    // Try to get a new message
    if(mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status)) {
#ifdef DEBUG_MODE
      outSerial.print("DEBUG msgID: ");
      outSerial.println(msg.msgid);
#endif
      // Handle message
      switch(msg.msgid)
#ifdef DEBUG_MODE            <TEST>
        case MAVLINK_MSG_ID_HEARTBEAT:  // #0:
            mavlink_heartbeat_t hb;
            mavlink_msg_heartbeat_decode(&msg, &hb);
            outSerial.print("custom_mode:       ");outSerial.println(hb.custom_mode);
            outSerial.print("type:              ");outSerial.println(hb.type);
            outSerial.print("autopilot:         ");outSerial.println(hb.autopilot);
            outSerial.print("base_mode:         ");outSerial.println(hb.base_mode);
            outSerial.print("system_status:     ");outSerial.println(hb.system_status);
            outSerial.print("mavlink_version:   ");outSerial.println(hb.mavlink_version);
          break;
        case MAVLINK_MSG_ID_RC_CHANNELS_RAW:  // #1: SYS_STATUS
            mavlink_rc_channels_raw_t chs;
            mavlink_msg_rc_channels_raw_decode(&msg, &chs);
            outSerial.print("Roll: ");outSerial.println(chs.chan1_raw);
          break;
        case MAVLINK_MSG_ID_ATTITUDE:
            mavlink_attitude_t attitude;
            mavlink_msg_attitude_decode(&msg, &attitude);
            outSerial.print("PX ATTITUDE: ");
            outSerial.println(attitude.roll);
          break;
#endif
        case MAVLINK_MSG_ID_COMMAND_LONG:
          if(outSerial.available()>0)
            //outSerial.write(c);
#ifdef DEBUG_MODE
            //Tets case
            outSerial.println(" Income MSG [-COMMAND_LONG-].");
#endif
          break;
        default:
#ifdef DEBUG_MODE
          outSerial.println(" Income MSG [--NO_SIMILAR--].");
#endif
          break;
#ifdef DEBUG_MODE
    //outSerial.println(" comm_receive() [close].");
#endif
PHOTO:
your problem was solved ??
@Bilal_Khan, hi!
I solved it, but it`s been a while so i can’t remember what was the exact solution.
If you use the STM32 MCU, you should switch to the STM32Cube IDE as i had problems with the Arduino IDE.
I suggest checking:
  1. Ardupilot settings. As i remember the MCU must/should be peripheral MAV type or something;
  2. (sounds dumb but…) Check your UART wires for any connection mistakes. Like RX->RX etc.;
  3. STM32 tick settings. Just i case;
  4. STM32 port settings. I don`t remember what checkbox but the port settings are essential. You can easily find articles about it even in the official documentation.
  5. The MCU source code itself. Debug every step, because the error may be in the system’s CompID as the simplest reason.
  6. The MCU`s default state is completely erased so if you wanna use ports you have to manually implement cycle buffer and interrupter(based on registers). This way your MCU will definitely receive a msg, even broken or incorrect. Again, search for something like “STM32 cycle buffer Arduino alike” on Google;
That`s all that came into my mind sorry)
Hello community,
I’m currently facing an issue while attempting to connect an STM32F103 microcontroller to Mission Planner (MP). I successfully used the following code with an Arduino Uno, establishing a connection with MP and sending the HEARTBEAT signal. However, when I tried the same code on the STM32F103, I encountered connection issues.
Here’s the code snippet that worked on Arduino Uno but faces difficulties on STM32F103:
#include <MAVLink.h>
void setup() {
  Serial.begin(57600);
void loop() {
  // Send HEARTBEAT message to Serial once a second
  mavlink_msg_heartbeat_pack(1, MAV_COMP_ID_AUTOPILOT1, &msg, MAV_TYPE_QUADROTOR, MAV_AUTOPILOT_GENERIC, MAV_MODE_FLAG_MANUAL_INPUT_ENABLED, 0, MAV_STATE_STANDBY);
  Serial.write(buf, len);
  delay(1000);
Any insights or suggestions on how to troubleshoot and make the STM32F103 connect successfully to Mission Planner would be greatly appreciated. Thank you in advance!
