I’ve been modifying/adjusting my quad to get good performance and it just continuously keeps going badly.
Basically flight always goes super well for about 2-4min before something goes wrong. The copter gets wobbly, and then quite rapidly loses altitude. Not quite just dropping from the sky, but definitely close. Almost like it’s losing battery, but I just don’t think that’s the case. Hoping someone here can give me some pointers.
I got a new frame based on some recommendations here actually. The new frame is a 500mm carbon fiber setup. Very sturdy. A little on the heavier side but not too bad.
It’s a quad setup using the SunnySkyA2212 980KVs (SunnySky A2212 Brushless Motors – SunnySky USA )
I suspected there might be an issue with the original battery. It’s a 50c 3s 3200mah battery. I’m flying with 10in props.
Thought maybe the battery was faulty, so purchased two add’l Ovonic 3s 50c 3000mah batteries.
Using PixHawk FC, with a Raspberry Pi CPU. 30a ESCs.
It feels really heavy. But the scale I use to weigh it says it’s 1.1kg. I don’t know how much I trust the accuracy of that though. It feels more like it’s probably closer to 2kg.
First day I got the new batteries, I used 1 and I was able to fly for about 4min. Took her pretty easy since I had a gut feeling the problems weren’t solved. After about 4min in, it started going… what I would call topsey turvy. Just started wobbling mid flight. Was able to keep enough control of it to land (barely).
So in my head I’m thinking, we’ll maybe 4min of flight is about right for only 3ah. Did some calculations using ecalc multi rotor calculator and it was coming out at about 5.5min of flight. So cool, maybe if I run the two new batteries in parallel to double that to 6ah. This should double my flight time. Ecalc was netting around 9min mixed flight time. And the extra battery only added 196g, so not too bad. Knew it wouldn’t be double flight time, but maybe 80% extra.
So got that all setup and yesterday took flight. Was airborne for all of 1:42 before it started going topsy turvy again from about 20m altitude.
At this point, I’m figuring it maybe is heavier than what I believe it is. So maybe 12in props versus 10 would give me the extra thrust I need. Or maybe go to an X8, and split the batteries back up, 1 for each set of 4 motors.
Or it could be a faulty motor (doesn’t seem like it though). So maybe a faulty ESC. Maybe an incorrect parameter in ArduPilot. Honestly I’m a bit lost at this point because my flight time with the current configuration should be much longer.
