Arduplane V4.0.9
channel 1= rudder
channel 2= elevator
channel 3= throttle
channel4= flaps
channel5= balance rudders ( ailerons)
channel 8 = flight modes
All channels exept 3 should have output without any arming, if the plane is in manual mode.
This is wanted, because I have to check manually that channel 1,2,4 and 5 responds normally before each flight, so I donbt mess up the connections to flaps and balance rudders. I have detachable wings with snap in connections.
I hope I havent made any mistakes.
Balance and flaps does not move, rudder and elevator is ok.
params.param (18.7 KB)
