Can not get parameters
Using tbs micro and apsync , not able to get parameters on both of them. I can see the sensors and telemetry but no Parameters are downloaded. Please share your sr config and MP also for a working system. Thank you!
Probably a TBS micro bug. please post your parameter file
setup1.param (20.7 KB)
here it is, although same setup i s working fine on copter. same issues with apsync. therefore i would not blame tbs.
Thanks!
I don’t know if this similar enough to what you’re doing or if it will help, but here’s what I had to do to get it to work for me.
Thank you! i do not belive it is a TBS related problem , same thing is happening with a CC. Have telemetry just no params.
