I am using a cube purple with the mini interface board and a here 2 gps. When the on board mag calibration is running, the status bars do not change and the text box is empty.
The internal compass will calibrate on version 3.6.11 but the external will not.
The interface board and gps are working correctly as long as a cube black is installed.
Thanks for your suggestion. Didn’t seem to help in this case. Maybe i will try a slightly higher value. I tried to roll back to 3.6.11 again and the parameter did not exist yet.
