I can’t change flight modes! I can’t fly until I can do that! - Everything else is in order.
Tx 3 position switch DOES appropriately change the Channel (5) on Radio Calibration in Mission Planner.
However when I move to Flight Modes - Flight Mode 4 is green and there seems to be no way to change it from that Flight Mode. Current PWM is 1498 which is in the range of my pwm output on channel 5.
I am using PPM mode and evidently need to change the default channel 8 to channel 5 in the parameters because my PWM on channel 8 is eratic and floats wildly.
Can you point me to where in the parameters you change the default channel from 8 to 5? Can’t seem to find it.
