Is it possible to assign one of the switches and channels (like channel 5) on my transmitter to arm and disarm the motor instead of using the “right or left rudder for a few seconds” method?
Thanks,
Paul
Thanks,
Paul
Based on the documentation (http://ardupilot.org/plane/docs/arming-throttle.html), I don’t think it’s possible to do switch arming with ArduPilot. The motive behind rudder arming with a “few seconds” delay is a safety feature to ensure that the arming process is deliberate; i.e. you cannot arm a plane with an accidental flick of a switch.
I do know of other flight configurators (e.g. BetaFlight configurator) that allow switch arming but don’t think that is very applicable to ArduPilot.
Edit: Actually, if you do want a “pseudo-arming” switch you might want to consider setting up a throttle cut function for one of the switches on your transmitter. How it is done will depend on your transmitter model.
Thanks for the information Lau. Paul
a very unsafe workaround that I highly advise against is to always enable arming and then have a switch on the transmitter to change the gain/scale of the transmitter throttle channel to essentially kill it (apply 0.01 gain)
Depending on transmitter really. On Taranis with OpenTX you can set a switch to override throttle and rudder channels with needed values for a few seconds to do arming. If you want, I can give you the exact setup how to do that.
