My plane is FPV Raptor, which have tendency to nose down at full throttle.
Currently I changed my motor to lower kv, but I will need to change back so I can put more gear in it. That is why I want to reduce the auto takeoff throttle to 60% - 75%.
[infoplane][/infoplane]
There is no way in the current code to change max thrust only for auto takeoffs. It’s a good question. I need the opposite as you. I would like 100% thrust only during auto takeoffs.
This could be resolved my adding a new parameter called THR_MAX_TAKEOFF.
I already have an old github request for this. I will add your request to it.
github.com/diydrones/ardupilot/issues/550
Hi zhoter,
There are a couple of things you can do.
StefanG, I’m not sure what other information you think is required?
Sam
This is more a tech support forum for end users, not a developer forum, so usually the supporters try to help the OP find a solution with their setup, not point them to the code.
Support requests should comply with some minimum requirements as described here: viewtopic.php?f=1&t=4582
Support requests should comply with some minimum requirements as described here: viewtopic.php?f=1&t=4582[/quote]
Fair enough, I only linked to the code for interest. I am hardly a developer but I always find it useful to look at the current code as it is less susceptible to becoming outdated or misunderstood than the documentation.
In any case the information I provided does not relate to code alteration but merely draws attention to the parameters which are likely to provide a solution, FBW_MAX and KFF_THR2PTCH.
Good news! Tridge has responded to my github issue on this matter and is adding a new parameter called TKOFF_THR_MAX
[quote=“Samuel Tabor”]Fair enough, I only linked to the code for interest. I am hardly a developer but I always find it useful to look at the current code as it is less susceptible to becoming outdated or misunderstood than the documentation.
In any case the information I provided does not relate to code alteration but merely draws attention to the parameters which are likely to provide a solution, FBW_MAX and KFF_THR2PTCH.[/quote]
No problem . I was just answering your question as precisely as possible .
Sent from my Ainol Novo 7 Fire using Tapatalk
Hi All,
Thank you for the support.
StefanG please accept my apology, I just think that the issue really airframe design dependent at start, but I presume that someone else would also need feature in some specific condition. Thank You.
zhoter: No need to apologize. It’s not personal! It’s just that it’s usually very hard to support users when they write nothing about their setup, software version, etc.
