Hi Can anyone is tried with cube orange plus interface with the Lora Module is it possible If possible,plz tell me know…
Why means im using Lora module means im present working on drones project in that im using Ardupilot code,
when the drone send the Data to the Lora module then the lora module send that data to the Lora Gateway and that lora Gateway is connected to the LAN or WIFI Networks and in that data send to the Cloud or server.
Have you considered the throughput and bandwidth needed to meet the requirement assuming it can interface?
Rather than rolling your own architecture, have a look at ExpressLRS Airport. You should get LoRa-like performance without the hassle of managing things at a low level.
If ExpressLRS range is inadequate, it’s likely that your own solution would be worse. LoRa tends to work best for applications that require less bandwidth than MAVLink.
Consider a 4G modem if you need longer range.
