I have a Nexus 7 with Android 4.4.2 and Droidplanner 1.2 installed. This is connected cia a USB-OTG cable to the ATMega 2.6. I can connect to the APM but it wiats indefinitely for data. What could be wrong? I did perform some tests as to see where the error could be.
- I used OTG trouble shooter to see whether I had an OTG connection. It says it has USB host support and OTG is detected. When I connect my SD card reader it detects a USB device in Linux and Android. It does not detect Linux and Android when I connect to APM. I assume this is normal as it tries to detect storage devices.
- MavLinkHub detects two Arduino Mega 2560 devices: one with long hexcode@16033 and the second with the same long Hexcode@16034. When I connect to the first one MavLinkHub crashes, the second Arduino Mega connects well. However, it also waits indefinitely for data.
- Droidplanner 2 connects but reports that the datalink is lost and I should check the connection
I am not sure what is wrong. Could someone help me out?
Thanks in advance!
Arnold
