Camera Trigger
I fly the Sony NEX7. I currently use this board for FPV and camera trigger.
http://www.overskyrc.com/hdmi-to-av-sony-converter-v2-new-version-p-479.html
It works well. However, I also want to be able to trigger the camera via Pixhawk for survey missions.
Can I use the Aux output as described here,
http://copter.ardupilot.com/wiki/common-optional-hardware/common-cameras-and-gimbals/common-pixhawk-auto-camera-trigger-without-chdk/#pixhawk_board
To drive the HDMI to AV board? If so, Would I maybe need a toggle switch between the Receiver and Pixhawk to toggle between the two control methods…
Or, Is my thinking completely wrong…?
Maybe if I re phrase the question. What is the difference between the rcvr out put and the aux output of the Pixhawk?
Can the rcvr out simply pass through the Pixhawk?
Thanks!
