Hi!
I have configured the camera trigger via AUX05 as described here:
(Camera Trigger Setup for Pixhawk — Copter documentation)
Our Pixhawk with the 4.2.3 firmware works fine, but the Pixhawk with the 4.3.6 does not.
I can’t get a signal change on my AUX for the Pixhawk with the newer firmware.
I went through all the parameters as recommended and the only difference I can see is that the earlier version has MNT and the newer one has MNT1 and MNT2 (the “Type” field of the gimbal configurator is also not active) and I can’t change it.
I would appreciate your advices.
Hello
I have the same problem as Stef an.
I am using copter 4.5.1 and I have two problems
I am not able to shut the camera. I am using RC7 Camera trigger and servo10 Camera trigger
2 I have assigned MNT1
I move the tilt at RC controller and the tilt servo moves
I move the Roll at RC controller and the Roll servo moves
I move the copter and the Servos Tilt and Roll moves but not enough
|MNT1_DEFLT_MODE|3| RC Targeting
|MNT1_NEUTRAL_X|50| I can change this parameter and nothing happens at Roll
|MNT1_NEUTRAL_Y|0| I can change this parameter and nothing happens at Pitch
|MNT1_NEUTRAL_Z|50|
|MNT1_PITCH_MAX|45| I can change this parameter and nothing happens at Pitch
|MNT1_PITCH_MIN|-110| I can change this parameter and nothing happens at Pitch
|MNT1_RC_RATE|0|
|MNT1_RETRACT_X|0|
|MNT1_RETRACT_Y|0|
|MNT1_RETRACT_Z|0|
|MNT1_ROLL_MAX|45|
|MNT1_ROLL_MIN|-45|
|MNT1_SYSID_DFLT|0|
|MNT1_TYPE|1|
|MNT1_YAW_MAX|180|
|MNT1_YAW_MIN|-180|
