Hi folks,
I uploaded the new ArduPlane 4.0.1 firmware to my Pixhawk 4 and tried to fly some Auto-WP missions to create some orthophotos.
I have the problem that the camera feedback trigger via hotshoe does not work properly. So I did some trials with the camera hooked up on the bench. I armed plane and then took about 18 pictures with the “Trigger camera NOW” command.
After downloading the logfile I tried to use the geo ref images tool and loaded the correct log and photos. When I choose Trigger Message as source it shows less trigger messages than actual picures taken.
Before the fw upgrade I used ArduPlane 3.9.7 and it worked fine (at least I did two missions with roughly 1800 pictures each and it worked perfectly!). So I tried to downgrade to 3.9.7 again. Thing is that no log is created in the earlier fw versions anymore. I checked the “LOG_BACKEND_TYPE” and its set to 1 and the bitmask is 65535. @tridge: What could cause that problem?
edit:
I downgraded my Pixhawk to 3.9.7 again and it says ChibiOS in message window:
07.12.2019 09:09:53 : Pixhawk4 00250022 31375101 36353937
07.12.2019 09:09:53 : ChibiOS: d2030d88
07.12.2019 09:09:53 : ArduPlane V3.9.7 (6a3513fb)
What I also find strange: when I update to 4.0.1 the time to connect to the Pixhawk 4 via MP takes longer than with the older firmwares…
@WickedShell have you got an idea why the previous versions of AP do no logging anymore? I will try a fresh SD card tonight but I would wonder if that would be the problem.
I bought a decent hot shoe adapter which solved the problem. I am using AP 4.0.9 and it works perfect (but it worked with previous versions as well).
edit:
One thing I forgot: I changed my FC to a Durandal. It deems to do the job better. With my Pixhawk 4 I could see the feedback (photo-image in Mission Planner) on the ground but not during a mission flight. This problem solved as well when I changed to Durandal.
