Hi, i had to test take picture using cam_trig_dist command automatic. like in auto grid it will have command automatic set by MP, now i want to test set cam_trigg_dist automatic but only use line not autogrid. can i do that thing? only use line that i mean to set automatic cam trigger.
i think this should work. I tried it in Rover some time ago and it worked with a simple mission (no grid).
You might just try to test it on the ground. Put in the distance and go for a walk with your setup
if i use do_set_cam_trigg_dist with manual point, what other other parameter should i set? to make shutter running well, because when i tested it, the trigger no running
