Copter: X8 Pixhawk 3.3-rc10
Camera: Sony ILCE-5100 remote camera trigger distance based
I get the following error when I try to geotag through MP:
Using AMSL Altitude True
Reading log for GPS Messages in order to get AMSL Altitude
Log Read for GPS Messages
Reading log for CAM Messages
Log Read with - 106 - CAM Messages found
Read images
Images read : 105
CAM Msgs and Files discrepancy. Check it!
which results in abort.
My question is … without a total loss of this flight, since it’s only 1 CAM Msg extra, is it possible to edit it out and rerun the geotagging tool?
Pix4D has processed this flight with decent results but would like to run through a different processing service which only accepts geotagged images.
[quote=“meee1”]I would suggest using the time offset method, and tick the “use cam messages” box.
this will time match based on just the cam messages.[/quote]
I just tried that and got many errors.
example :
Photo DSC00983 PROCESSED with GPS position found 0 ms away
Photo DSC00984 PROCESSED with GPS position found 800 ms away
Photo DSC00985 PROCESSED with GPS position found 400 ms away
Photo DSC00986 PROCESSED with GPS position found 200 ms away
Photo DSC00987 NOT PROCESSED. No GPS match in the log file. Please take care
Photo DSC00988 NOT PROCESSED. No GPS match in the log file. Please take care
Start Processing
Done
So out of 100 images, maybe 10% was correctly geotagged.
Is editing the log files that difficult? It would be worth the effort for me in this case.
This still is an issue with the FW and this method still works. My camera always triggers once when the autopilot boots up but there is no message for it, so I always have to delete the first picture in the folder.
