Calibrating BATT_AMP_PERVLT
I’m using a CubePilot Mini Power Brick on a quad-copter I’m evaluating.
After entering the voltage so that the voltage-divider can be calculated, I started with BATT_AMP_PERVLT of 17 - as described in the parameters wiki.
This value is quite off - but it’s a place to start.
As a guess, the voltage output for the current sensor is linear - or close to it. I’d appreciate comments if this guess is wrong.
To calibrate BATT_AMP_PERVLT I did a test flight with a fully charged battery, and compared the total current recorded in the log file for the flight with current required to recharge the battery.
I then adjusted BATT_AMP_PERVLT by the percentage difference. For example, if the current total was 20% lower than the current required to recharge the battery, I increased BATT_AMP_PERVLT by 20%.
I’ve not read anywhere that this is a valid technique. If it’s problematic, I’d really appreciate comments.
No, that is exactly the recommended procedure.
Search the forum for:
New Amps/volt = old amps/volt x charger mah ÷ logged mah
Or some version of that and you will find plenty of posts describing that procedure.
Or just searching for “ratiometric” will do it.
This is what you did, and it’s the way many have done it and I recorded the steps:
Here’s how to adjust your Amps Per Volt
  • Plug in a fresh battery and do a hover flight for 5 minutes or until you’ve used a significant amount of battery capacity
  • Immediately unplug the battery and charge it, note how many mah’s it took to charge. Let’s say that was 1,500 mah
  • Download your log and look at maximum CurrTot. Let’s say it was 1,300 mah
  • Get your existing BATT_AMP_PERVOLT setting from Mission Planner
  • NEW_AMPS_PER_VOLT = OLD_AMPS_PER_VOLT x CHARGED_MAH / LOGGED_MAH
    With my example numbers, you’d get
    NEW_AMPS_PER_VOLT = 17 x 1,500 / 1,300 = 19.61
  • Set the new value in the BATT_AMP_PERVOLT parameter and save to your copter
  • Fly to check, repeat until you’re happy the new value gives consistent readings
I expect one additional reason it’s important to calibrate the current sensor is if you have COMPASS_MOTCT=2 then the current flow is used to calibrate the compass.
Correct, and you can even produce the compass/motor params offline with magfit, instead of trying to kill yourself running the copter at high throttle levels with the props on.
I always use MagFit.
I can’t figure out why everyone doesn’t.
