I have installed a piezo buzzer on my drone, it works, but when I plug in the battery it plays a long annoying tone at startup then starts the normal Arducopter startup tone.
Is there a way to avoid this long loud and annoying tone when connecting the battery?
I do not wish to turn it off or make it less noisy, what I would like to do is to remove the continuous tone at startup, just like the Pixhawk or Pixracer does.
If im not mistaken, you need modify the code for remove it… but its not adviced coz the buzzer tone can give you the idea of what happening on the drone…
However, I don’t think we are on the same page. Maybe you haven’t experienced this situation. The idea is to keep the buzzer. The only “problem” is the constant tone at start up before it goes into the normal startup tone stage. In other words, the buzzer works as expected, the only difference with the pixhawk buzzer is the loud tone at start up.
Why would I remove it from the code? actually I don’t even understand what you mean by removing it…
I think what he is trying to say that buzzer should not buzz for first few seconds while booting (just before the final boot-up musical tone).
Normally you plug in the battery,everything is silent and after few seconds when the bootup process finishes,you hear musical tones.
But on some boards(i am experiencing in one of the omnibusf4V3pro board too) buzzer starts buzzing the moment you plug in the battery and its annoying to hear continuous tone for first few seconds before the musical tones.
if he is referring to this, On all my boards i don’t have that issue of the buzz, it depends also about the quality of the buzzer he is using and also maybe about the signal density.
Type of buzzer makes a difference - this from an earlier discussion
Pixhawks use “passive” / piezoelectric buzzers (which act kinda like a speaker) that are controlled by PWM signals (and can play many tones), while the Betaflight-type boards are meant to use “active” buzzers which only use voltage (and no PWM), and only play ONE tone
Hey @uncletom thanks for the clarification, does it mean there is a way to solve this situation? or is by nature like that and there’s not much we can do?
