Burned ESC at first take off
Hi all,
I just finished my dron build and tried to take it off for the first time.
I did a acceleration and smoke started instantly on one of the ESC which catched fire !!!
A managed to remove the battery quickly and stop it, as only the ESC seems to be damaged…
My drone build:
  • Motor ==> Emax 2808 850KV with prop 1045 asking for a 4 cells battery. Max thrust at 16 Amp
  • Battery ==> 6750 mAh 70C covering the energy need
  • ESC ==> 30A, bought from aliexpress
My thoughts are:
  1. Bad quality ESCs, as some of you in the forum experienced…
  2. two much current on the engines ?
Thanks for you help…
I ordered good ESCs to change them. I hope motors are sill good…
That would be my guess. Hopefully they are not this junk?
Haha close to this… I prefer not to show you the pic :slight_smile:
I will receive the new ones tomorrow, hopefully motors are not damaged.
Thanks Dave.
https://es.aliexpress.com/item/32836070082.html
Be careful: these are
Voltage: 2-3 S LiPo
If this is the case, the other ESC’s have no reliability.
Thanks Dave. This is the one I ordered:
https://www.amazon.fr/gp/product/B07VT3NPW5/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Those are really best suited for a fixed wing motor. I suppose they could work for a multirotor but not a good choice. Buy some branded Blheli_32 ESC’s.
It burned again !
I don’t understand what is wrong with my build…
It killed two motors too… Is the battery too powerful ? Is the throttle two sensitive to that is loads the engine two much ?
Thanks.
Check also for continuity. Maybe a short somewhere or a bad soldering
Thanks AndreSRC. I will spend some time to check that.
Is my understanding correct : Battery delivers what is asked to it ==> The fact that it can deliver way more current that motors can handle is good.
Thanks again for your help
Yes. A battery with higher C rate is better.
Motor mount screws too long and cutting into motor windings are one possible explanation.
Also aluminium or carbon fibre conducts and could be contributing to a short.
Can I ask what voltage range your battery operates at?
The battery is a 4s. 14.8V.
I will have a look at the mounting screws.
I think I may have a root cause as the three wires of the motors might touch each other and make a short.
