Hi all, have been using realflight to mess with the tailsittter code and I must say it works very nicely. I have been playing with the physics of my realflight FT bronco model to try and get it to be more realistic. I am having a couple of issues.
Firstly the realflight landing gear seems to do nothing, is this because I don’t have proper visual frames set up for it? This is annoying as the rounded fuselage in the CUAV TVBS graphics I am using causes the aircraft to drop a wing to one side or the other when on the ground.
I have selected the right size motors and props and the aircraft hovers at the same throttle percentage as the real one. The realfight model however reaches about 50m/s at full throttle where as the real one only gets to 25-30m/s. I need more drag. I have tried increasing fuselage frontal drag percentage to 1000%, this has no effect. Only way i could get it to slow down was increasing the wing parasitic drag to 200% this is the maximum value and this only slows the aircraft by 3 or 4 m/s. Any ideas?
Quite frustrating how linked the physics is the the visuals. I don’t really need it to look right, just fly right, although it is useful to see the control surfaces moving.
hi everyone,
KnifeEdge have now released a beta which supports up to 12 actuators for the FlightAxis protocol, which means we can build aircraft with up to 12 channels. This really helps with more complex aircraft.
See the announcement here: http://www.knifeedge.com/forums/showthread.php?t=33513
I’ve pushed a change into master to take advantage of the extra channels. I’ve also tested to ensure that sending 12 channels doesn’t break anything with the older version of realflight.
Cheers, Tridge
12? Its better than 8, but I already have a design I’m working on that needs 12 for the copter, 1 for mode changes, 1 for retracts, 3 for the gimbal, 1 for a sprayer channel, 1 for arm/disarm, and probably more… why not just make it 24 or more and be done with it?
because the internal structure of RealFlight makes going to 12 easy. Going to more than 12 is a much bigger job, and not something they can take on right now.
In the real vehicle, we passthru sbus signal out from pixhawk to another microcontroller, and it needs to be aware of mode changes and arming state, and currently gets this info via sbus signalling two servo out channels, which isn’t perfect, but works. We cant sim this at present ,but would like to
you can simulate that actually, just set one of the SERIALn_PROTOCOL channels as SBUS_OUT, and connect a real UART (see wiki) using USB serial adapter. Then the real external microcontroller can get data while flying with SITL in RealFlight.
The 12 channel limit is only on what goes into RealFlight. You can have 16 channels running with SITL, and output them all via other protocols (including SBUS).
Cheers, Tridge
I’m looking to simulate an octa-rotor tailsitter (design attached). I’m struggling with 3DS Max, can someone help freelance in modeling this design in 3DS Max so that it can be imported into RF8?
8 motors should be fine, you get 12 outputs. If your just interested in the physics you don’t need to import the model you can just change the physics of a existing model, it just wont look right.
However, I could not get them flying as the models are not sitting on their tail and I do not know how to take-off in this case. In order to quickly get something up and running, I went ahead to modify “CatTailsitter” by Tridge. I used 3ds max to duplicate the frame and motors (to create a quadrotor tailsitter with 2 wings), then I imported this into RF8 and edited the aircraft to manage CoG etc., Please find attached the file in RFX format. I connected this with SITL, unfortunately I am unable to take-off properly. I’m not sure if I’m using wrong params or if I haven’t named the motors in the right order. I’ve double cross-checked, but I’m unable to find anything wrong
That’s right, and my quad tailsitter models should already have been set for hand launch.
Hand launching in QHOVER mode should work fine if the tuning is reasonable.
Are there any here who specialize in building RealFlight models that we can use for simulation? We have our complete UAV in Solidworks and need a custom model due to its unique propulsion layout.
Hello Robert, I successfully implemented a VTOL tilt rotor in RealFlight 7 including the gyro stabilization within the same software. I am yet to open up the wallet to purchase RealFlight 9 for full integration to ArduPilot, but I don’t think the principle of how to build models within RealFlight changes. Send me a private message if you are interested in working with me.
You’re in luck! Brandon MacDougall and myself have started working more on models lately. You can join the discussions on the simulation channel on the ArduPilot discord server.
Here is what we’ve been working on lately:
