trying to build with qt creator,
with windows MSVS 2019 it compiles to produce “qgroundcontrol.exe”
but “Apk” is not generated. Exist with error:
10:42:07: Running steps for project qgroundcontrol…
10:42:07: Starting: “C:\Qt\5.15.2\android\bin\qmake.exe” C:\Users\SaddiPC\Desktop\qgc\qgroundcontrol\qgroundcontrol.pro -spec android-clang “CONFIG+=qtquickcompiler” ANDROID_ABIS=“arm64-v8a”
‘which’ is not recognized as an internal or external command,
operable program or batch file.
Project MESSAGE: Qt version 5.15.2
Project MESSAGE: Android Arm 64 bit build
Project MESSAGE: Daily Build
Project MESSAGE: GIT_DESCRIBE v4.2.0-343-g4e7f2f88e
Project MESSAGE: QGroundControl APP_VERSION_STR VERSION v4.2.0-343-g4e7f2f88e 4.2.0.343
Project MESSAGE: VERSION 4.2.0.343
Project MESSAGE: Android version info: 664200343 bitness:66 major:4 minor:2 patch:00 dev:343
Project MESSAGE: Release flavor
Project MESSAGE: Skipping support for Pairing
Project MESSAGE: Using MAVLink dialect ‘ardupilotmega’.
Project MESSAGE: ANDROID_EXTRA_LIBS
Project MESSAGE: arm64-v8a
Project MESSAGE: C:/Users/SaddiPC/Desktop/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/arm64/libcrypto.so C:/Users/SaddiPC/Desktop/qgc/qgroundcontrol/libs/OpenSSL/android_openssl/arm64/libssl.so
Project MESSAGE: Skipping support for Zeroconf (unsupported platform)
Project MESSAGE: Including support for AirMap
Project MESSAGE: Taisync disabled
Project MESSAGE: Microhard disabled
Project MESSAGE: Skipping support for video streaming (GStreamer libraries not installed)
Project MESSAGE: Installation instructions here: qgroundcontrol/README.md at master · mavlink/qgroundcontrol · GitHub
Project MESSAGE: Adding Serial Java Classes
Project MESSAGE: This project is using private headers and will therefore be tied to this specific Qt module build version.
Project MESSAGE: Running this project against other versions of the Qt modules may crash at any arbitrary point.
Project MESSAGE: This is not a bug, but a result of using Qt internals. You have been warned!
10:43:01: The process “C:\Qt\5.15.2\android\bin\qmake.exe” exited normally.
10:43:01: Starting: “C:\Users\SaddiPC\AppData\Local\Android\Sdk\ndk\25.1.8937393\prebuilt\windows-x86_64\bin\make.exe” -f C:/Users/SaddiPC/Desktop/qgc/build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Release/Makefile qmake_all
make: Nothing to be done for ‘qmake_all’.
10:43:03: The process “C:\Users\SaddiPC\AppData\Local\Android\Sdk\ndk\25.1.8937393\prebuilt\windows-x86_64\bin\make.exe” exited normally.
10:43:03: Starting: “C:\Users\SaddiPC\AppData\Local\Android\Sdk\ndk\25.1.8937393\prebuilt\windows-x86_64\bin\make.exe” -j4
rcc qgroundcontrol_qmlcache.qrc
rcc src_FirmwarePlugin_APM_APMResources_qmlcache.qrc
rcc src_FirmwarePlugin_PX4_PX4Resources_qmlcache.qrc
rcc src_Airmap_dummy_airmap_dummy_qmlcache.qrc
linking libQGroundControl_arm64-v8a.so
echo Post Link Common
Post Link Common
10:43:40: The process “C:\Users\SaddiPC\AppData\Local\Android\Sdk\ndk\25.1.8937393\prebuilt\windows-x86_64\bin\make.exe” exited normally.
10:43:40: Starting: “C:\Users\SaddiPC\AppData\Local\Android\Sdk\ndk\25.1.8937393\prebuilt\windows-x86_64\bin\make.exe” “INSTALL_ROOT=C:\Users\SaddiPC\Desktop\qgc\build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build” install && cd C:\Users\SaddiPC\Desktop\qgc\build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Release && C:\Users\SaddiPC\AppData\Local\Android\Sdk\ndk\25.1.8937393\prebuilt\windows-x86_64\bin\make.exe “INSTALL_ROOT=C:\Users\SaddiPC\Desktop\qgc\build-qgroundcontrol-Android_Qt_5_15_2_Clang_Multi_Abi-Debug\android-build” install
make: *** No rule to make target ‘install’. Stop.
10:43:41: The process “C:\Users\SaddiPC\AppData\Local\Android\Sdk\ndk\25.1.8937393\prebuilt\windows-x86_64\bin\make.exe” exited with code 2.
Error while building/deploying project qgroundcontrol (kit: Android Qt 5.15.2 Clang Multi-Abi)
The kit Android Qt 5.15.2 Clang Multi-Abi has configuration issues which might be the root cause for this problem.
When executing step “Copy application data”
10:43:41: Elapsed time: 01:34.
THis is my first experience with qt creator and have not build any apk before, plz help @DonLakeFlyer @DomenicoPatella
