I’m trying to build Microsoft’s thermal soaring implementation (https://github.com/microsoft/Frigatebird) for SITL simulations on Ardupilot, and I’m following the build instructions from the Github repository’s BUILD.md
However, I’m getting this error when running “./waf distclean” in Cygwin on a Windows 10 machine with Python 3.7 installed:
$ ./waf distclean
Traceback (most recent call last):
File "/home/User/Frigatebird/modules/waf/waflib/Node.py", line 590, in ant_iter
raise StopIteration
StopIteration
The above exception was the direct cause of the following exception:
File "/home/User/Frigatebird/modules/waf/waflib/Scripting.py", line 165, in waf_entry_point
run_commands()
File "/home/User/Frigatebird/modules/waf/waflib/Scripting.py", line 262, in run_commands
parse_options()
File "/home/User/Frigatebird/modules/waf/waflib/Scripting.py", line 214, in parse_options
Context.create_context('options').execute()
File "/home/User/Frigatebird/modules/waf/waflib/Options.py", line 271, in execute
super(OptionsContext, self).execute()
File "/home/User/Frigatebird/modules/waf/waflib/Context.py", line 205, in execute
self.recurse([os.path.dirname(g_module.root_path)])
File "/home/User/Frigatebird/modules/waf/waflib/Context.py", line 287, in recurse
user_function(self)
File "/home/User/Frigatebird/wscript", line 53, in options
opt.load('compiler_cxx compiler_c waf_unit_test python')
File "/home/User/Frigatebird/modules/waf/waflib/Context.py", line 197, in load
fun(self)
File "/home/User/Frigatebird/modules/waf/waflib/Tools/compiler_cxx.py", line 103, in options
opt.load_special_tools('cxx_*.py')
File "/home/User/Frigatebird/modules/waf/waflib/Context.py", line 609, in load_special_tools
lst = self.root.find_node(waf_dir).find_node('waflib/extras').ant_glob(var)
File "/home/User/Frigatebird/modules/waf/waflib/Node.py", line 683, in ant_glob
ret = [x for x in self.ant_iter(accept=accept, pats=[to_pat(incl), to_pat(excl)], maxdepth=kw.get('maxdepth', 25), dir=dir, src=src, remove=kw.get('remove', True))]
File "/home/User/Frigatebird/modules/waf/waflib/Node.py", line 683, in <listcomp>
RuntimeError: generator raised StopIteration
Is this an issue with one of the Python modules?
