Building a VTOL tandem
the airframe itself is finished, the fuselage is fiberglass, the wings are foam glued with fabric 62 gr / square meter, I do separate power, the 6S running batteries will be separate.for take-off separately 6S, presumably the take-off weight will be about 7.5 kg
Uploading: DSC04581.jpg…
Nice airframe. Why did you build in 4 ailerons ? In any case,I wish that it flies as well as it looks.
Rolf
Thank you, I found a picture on the Internet and tried to make it look like the original, I hope I can teach him to fly) if everything is in order, I will switch to an internal combustion engine later
