I’m building the rover on cygwin from the latest ardupilot source and am having problems building uavcan as seen in below error.
Compiler failure
Traceback (most recent call last):
File “/home/PowerUsermodify/newtest/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdlc”, line 61, in
dsdlc_run(args.source_dir, args.incdir, args.outdir)
File “/home/PowerUsermodify/newtest/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 63, in run
run_generator(types, output_dir)
File “/home/PowerUsermodify/newtest/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 112, in run_generator
die(ex)
File “/home/PowerUsermodify/newtest/ardupilot/modules/uavcan/libuavcan/dsdl_compiler/libuavcan_dsdl_compiler/init.py”, line 90, in die
raise DsdlCompilerException(str(text))
DsdlCompilerException: line 16, col 17: invalid syntax (, line 1)
My build configuration output is below if it helps.
$ ./waf configure --board=CubeBlack
Setting top to : /home/PowerUsermodify/newtest/ardupilot
Setting out to : /home/PowerUsermodify/newtest/ardupilot/build
Autoconfiguration : enabled
GCOV code coverage analysis : no
Setting board to : CubeBlack
Using toolchain : arm-none-eabi
Checking for ‘g++’ (C++ compiler) : /cygdrive/c/Program Files (x86)/GNU Tools ARM Embedded/6 2017-q2-update/bin/arm-none-eabi-g++
Checking for ‘gcc’ (C compiler) : /cygdrive/c/Program Files (x86)/GNU Tools ARM Embedded/6 2017-q2-update/bin/arm-none-eabi-gcc
Checking for c flags ‘-MMD’ : yes
Checking for cxx flags ‘-MMD’ : yes
Checking for program ‘make’ : /usr/bin/make
Checking for program ‘arm-none-eabi-objcopy’ : /cygdrive/c/Program Files (x86)/GNU Tools ARM Embedded/6 2017-q2-update/bin/arm-none-eabi-objcopy
Including /home/PowerUsermodify/newtest/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/fmuv3/hwdef.dat
Adding environment OPTIMIZE -O3
Removing PB0
Removing PB1
Setup for MCU STM32F427xx
Writing hwdef setup in /home/PowerUsermodify/newtest/ardupilot/build/CubeBlack/hwdef.h
Writing DMA map
Generating ldscript.ld
Adding defaults.parm
Checking for env.py
env set DEFAULT_PARAMETERS=/home/PowerUsermodify/newtest/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/CubeBlack/defaults.parm
env set MAIN_STACK=0x400
env set APJ_BOARD_TYPE=STM32F427xx
env set IOMCU_FW=0
env set APJ_BOARD_ID=9
env set HAL_WITH_UAVCAN=1
env set FLASH_RESERVE_START_KB=16
env set CHIBIOS_BUILD_FLAGS=USE_FATFS=yes MCU=cortex-m4 ENV_UDEFS=-DCHPRINTF_USE_FLOAT=1 CHIBIOS_PLATFORM_MK=os/hal/ports/STM32/STM32F4xx/platform.mk CHIBIOS_STARTUP_MK=os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32f4xx.mk
env set CPU_FLAGS=[’-mcpu=cortex-m4’, ‘-mfpu=fpv4-sp-d16’, ‘-mfloat-abi=hard’, ‘-u_printf_float’]
env set OPTIMIZE=-O3
env set PROCESS_STACK=0x2000
Enabling ChibiOS asserts : no
Checking for intelhex module: : disabled
Checking for HAVE_CMATH_ISFINITE : no
Checking for HAVE_CMATH_ISINF : no
Checking for HAVE_CMATH_ISNAN : no
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : no
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : no
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : no
Checking for header endian.h : not found
Checking for header byteswap.h : not found
Checking for HAVE_MEMRCHR : no
Checking for program ‘python’ : /usr/bin/python
Checking for python version >= 2.7.0 : 2.7.16
Source is git repository : yes
Update submodules : yes
Checking for program ‘git’ : /usr/bin/git
Gtest : STM32 boards currently don’t support compiling gtest
Checking for program ‘arm-none-eabi-size’ : /cygdrive/c/Program Files (x86)/GNU Tools ARM Embedded/6 2017-q2-update/bin/arm-none-eabi-size
Benchmarks : disabled
Unit tests : disabled
Scripting : disabled
Scripting runtime checks : enabled
Checking for program ‘rsync’ : /usr/bin/rsync
‘configure’ finished successfully (40.426s)
