You don’t have any problem with the driver or the build.
You just cannot upload the new firmware.
Check your cable, your USB port and try upload the fw separately from the build process.
okay…got it…but seems like no luck by doing that…any other suggestion?
One more thing added to the things above, do not use USB hub, connect directly to your computer.
connected directly as well…but no luck still…
Just to make it sure, based on the screenshoot you using Ubuntu and not in a virtual environment.
yes I’m using ubuntu 22.04.3 LTS, Gnome version 42.9 and kernel 6.2.0-36-generic…still does not catch whats exactly is the issue?? please assist…
