Bug report
Issue details
When build rover in macos mojave with python2.7, the build failed in 493/495 with TypeError:
Build failed
Traceback (most recent call last):
File "/Users/apple/workspace/ardupilot/modules/waf/waflib/Task.py", line 338, in process
ret = self.run()
File "Tools/ardupilotwaf/chibios.py", line 78, in run
if defaults.find():
File "/Users/apple/workspace/ardupilot/Tools/scripts/apj_tool.py", line 93, in find
i = self.firmware[self.offset:].find(magic_str)
TypeError: argument should be integer or bytes-like object, not 'str'
Version
master- 49b0a00
Platform
[ ] All
[ ] AntennaTracker
[ ] Copter
[ ] Plane
[ * ] Rover
[ ] Submarine
Logs
[493/495] apj_tool build/CubeBlack/bin/ardurover
Loaded binary file of length 2294780
Waf: Leaving directory `/Users/apple/workspace/ardupilot/build/CubeBlack'
Build failed
ret = self.run()
if defaults.find():
The configuration information is as below:
➜ ardupilot git:(master) ./waf configure --board CubeBlack --python=python2
Setting top to : /Users/apple/workspace/ardupilot
Setting out to : /Users/apple/workspace/ardupilot/build
Autoconfiguration : enabled
GCOV code coverage analysis : no
Setting board to : CubeBlack
Using toolchain : arm-none-eabi
Checking for 'g++' (C++ compiler) : /usr/local/bin/arm-none-eabi-g++
Checking for 'gcc' (C compiler) : /usr/local/bin/arm-none-eabi-gcc
Checking for c flags '-MMD' : yes
Checking for cxx flags '-MMD' : yes
Checking for program 'make' : /usr/bin/make
Checking for program 'arm-none-eabi-objcopy' : /usr/local/bin/arm-none-eabi-objcopy
Including /Users/apple/workspace/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/fmuv3/hwdef.dat
Adding environment OPTIMIZE -O3
Removing PB0
Removing PB1
Setup for MCU STM32F427xx
Writing hwdef setup in /Users/apple/workspace/ardupilot/build/CubeBlack/hwdef.h
Writing DMA map
Generating ldscript.ld
Adding defaults.parm
Checking for env.py
env set OPTIMIZE=-O3
env set HAL_WITH_UAVCAN=1
env set PROCESS_STACK=0x2000
env set MAIN_STACK=0x400
env set IOMCU_FW=0
env set CPU_FLAGS=['-mcpu=cortex-m4', '-mfpu=fpv4-sp-d16', '-mfloat-abi=hard', '-u_printf_float']
env set APJ_BOARD_ID=9
env set APJ_BOARD_TYPE=STM32F427xx
env set FLASH_RESERVE_START_KB=16
env set DEFAULT_PARAMETERS=/Users/apple/workspace/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/CubeBlack/defaults.parm
env set CHIBIOS_BUILD_FLAGS=USE_FATFS=yes CHIBIOS_STARTUP_MK=os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32f4xx.mk CHIBIOS_PLATFORM_MK=os/hal/ports/STM32/STM32F4xx/platform.mk MCU=cortex-m4 ENV_UDEFS=-DCHPRINTF_USE_FLOAT=1
Enabling ChibiOS asserts : no
Checking for intelhex module: : disabled
Checking for HAVE_CMATH_ISFINITE : yes
Checking for HAVE_CMATH_ISINF : yes
Checking for HAVE_CMATH_ISNAN : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : yes
Checking for header endian.h : not found
Checking for header byteswap.h : not found
Checking for HAVE_MEMRCHR : no
Checking for program 'python' : python2
Checking for python version >= 2.7.0 : 2.7.16
Source is git repository : yes
Update submodules : yes
Checking for program 'git' : /usr/bin/git
Gtest : STM32 boards currently don't support compiling gtest
Checking for program 'arm-none-eabi-size' : /usr/local/bin/arm-none-eabi-size
Benchmarks : disabled
Unit tests : disabled
Scripting : disabled
Scripting runtime checks : enabled
Checking for program 'rsync' : /usr/bin/rsync
