I want to build a 2nd additional ground station, which only listens to the transmitted data from the drone but is not coupled to it, that’s what the first ground station is for.
Now only one station is connected to the drone. This then shares the data with the other. Is there a way that both ground stations are directly connected to the drone via telemetry?
So that if one of them has no reception anymore, I can still look at the other one?
Or is it possible to connect 2 antennas to a ground station and automatically select which one will be used, depending on which one has a better connection?
