Trying to load a map in mission planner seems to take a really long time. I loaded a map that took 36 hours to load and it’s not a very large area.
I am holding down the ALT key while dragging the area that I want to get. From there I right click and select prefetch map. Loading seems to go pretty fast at first then seems to really slow down.
Thing I have tried:
Uninstalling and reinstalling Mission Planner.
Multiple computers
Different wireless networks
Removing all Mission Planner data from registry
Anyone else having this issue?
Is there a fix or an update to mission planner that fixes the issue?
How big is the area? Do you really need the most zoomed in tiles? Can you tell us at which level it seems to noticably slow? Send a screen grab, if you use the Google Hybrid that is a lot of data.
I’m also trying to prefetch a very small area and its rediculously slow.
An area the size of 3 football fields, took 4 hours to complete.
After level 22, it crawls.
Internet connection is 25dwn/10up.
I tried this on 3 different PCs and laptops.
Exactly the same thing. All with v3.1.7 of MP.
Also tried this from a couple different locations, with different internet speeds.
Doesn’t seem to make any difference.
So either Google is throttling or there’s an issue with MP.
I just delete out all the cached maps from Mission Planner and then fire it up. Go to the area I plan to fly and copy the newly created folders to my tablet adding the .nomedia tag to each subfolder so they don’t show up in my photo viewer. Very fast this way.
