Not sure if its a bug or setting problem, rover is configured as skid steer type, if MOT_PWM_TYPE sets to normal, after power on and arm, servo1 and servo3 pwm output start with trim value, and range from min to max, no problem.
However, if change from normal to BrushedBipolar, after power up, servo output will change to min 1000, trim 1000, max 2000, regardless whatever I set and saved previously. If I then change min trim max value to different numbers, servos will work as expected, but after another power off and on, all settings lost.
I’m using rover 4.1.0 rc2 and updated to latest 4.2.0 dev, both not working properly.
Set mot type to normal will change output pwm freq to about 50 hz, and duty cycle within a small range. BrushedBipolar can have full duty cycle from 0 to 100% and pwm freq changeable from 1k and 20k, which meet the requirements of some PWM to analog converters
Managed to download the .bin file but can’t upload due to size?(file less than 1M). let me know if need more info.
Thank you Randy for the info, the link you provided looks like similar problem related to brushed motor configuration.
I already tried latest 4.2.0 dev firmware with no good. For now I have to use Lua to initialise those parameters after each reboot.
Around 1000,1400,1800. at 1000 servo output pwm duty cycle is zero.
Now the problem is, when power on, servo pwm output is zero, the bipolar brushed motor and rover will run reversly until arming, then the PWM set to 1400 neutral and rover will stop. This may cause danger with unwanted rover movement, not sure if you have any suggestions.
With the help of the log I was able to track it down. I could not reproduce in the simulator because it is related to the BHeli code that is only used on real hardware.
