Hello everyone,
I am new to the Ardupilot world, but have been working here and there with drones for 6-7 years now. I’ve been getting more technical, and started a project, to build a body board airboat with mapping capabilities, using a Kogger sonar. It’s the first ever RC build I’m doing, and intend to use it for general hydrological research, provided that the budget for turn-key solutions is out of the question. I’ve been inspired by Randy’s bodyboard mapping boat, so here I am, stuck with a technical issue. It’s been many months since I’ve started the documentation and concept stage, and have been torn to chose between 2 underwater thrusters and 2 brushless motors with propellers, that would provide “air power”. Considering that most water bodies that will be scanned are significantly invaded by shallow, underwater vegetation, I’ve finally decided to take the “2 air motor - thrust” way. I intend using a 42" bodyboard (900 grams), and a 20.000mah - 14.8 or 22.2 V battery, and a 2.4.8. Pixhawk controller. I am aware that air-power is significantly lower-efficiency than underwater thrusters (such as the already-classic T200 thrusters). The boat will weigh an estimated 6 kg-ish (I’m still waiting for many parts), and I aim for a 1,5-3m/s cruise speed, and as high autonomy, as possible. There will be no rudder, but differential thrust, using the 2 motors.
I’ve never chosen parts for a RC build before, and I’m not sure what pair of brushless motors I should chose, and with what corresponding propellers (I’m thinking of a maximum prop size of 9-10 inches, maybe?). Could you please provide some recommendations or specs? I’d appreciate it, if you could possibly link any European-sourced parts…
The science of motor+propeller combo’s is really overwhelming (I’ve even searched for efficiency curve-graphs for motors or online consumption calculations, but these are only theoretical pieces of information, and I would need some first-hand knowledge…), and I would really appreciate your experience and recommendations.
Any thoughts on this would be highly appreciated! Thanks
Bodyboard mapping airboat - motor and prop choice
After a little research, I have narrowed my list, down to a few choices:
- 2 x Tarot 4006 motors (4S compatible), which draw a maximum of 14 Amps
- 2 x Tarot 4008 motors (6S compatible), which draw a maximum of 30 Amps
I would use either models with some 11" props (1155 carbon fiber props), as they’re the maximum I can easily put on the bodyboard.
Still, I am not sure which motors would provide enough thrust and longer range, with a 20000mAh battery. My reasoning is that I could go for the Tarot 4006, with a 20000mAh, 4S battery (1,8kg), and get a good range, because the battery is almost 1 kg lighter, or maybe I could go with the Tarot 4008, with a 20000mAh, 6S battery (2.7 kg) and still get good range, because the motors would be working at the same thrust, but there will be less strain on the motors, being used at lower revs, therefore, at a higher efficiency.
Considering it’s my first build, I am not sure which variant would provide best range, or what would be the logical, better choice.
Any ideas?
I have built a few RC airboats and I would steer clear of using a body board if you can. My first RC airboat was done like this and the design of body boards wasn’t suitable.
Thanks for replying. Still, what drawbacks/issues would a body board bring to the table? Is it because it’s too light?
Depending on the board of coarse, I had issues with buoyancy. Being quite thin at the sides water can splash up easily and a small amount of weight puts it below the waterline , although it wont sink. Secondly they don’t plane well , you may get excessive drag which can cause porpoising , poor steering and poor speed. It can be very inefficient where battery life is concerned .
I ended up scratch building one from Styrofoam and coating with fibreglass.
Here is a video of it (turn the sound down ).
And my 3rd build
Those boats look really nice!
However, I see you’re using large, gas engines, to power them. Considering I intend to use this boat only for mapping purposes, I don’t think I’ll be going over 1.5m/s. Your boats are way faster than that! And with that kind of speed, comes great instability
Still, what kind of buoyancy issues did you have? how much weight did you put on the body board? And how large was the body board?
I agree with the steering part - this is probably going to be a challenge to dial just right, in the ArduPilot parameters, so that it steers properly, while doing autonomous missions… but hope it’s still gonna be manageable to steer. I’m thinking of mounting a rail of some sort underneath the body-board, to act as a boat keel, so that it could more easily maintain straight lines, while driving across the water.
If you are going slow a water rudder would be better. Adding keels would help keep it straight. I once used an old heli gyro to aid with steering and it worked well so an FC should have no trouble keeping the turns and straights nice. I guess you could prove your concept on the body board then if you have no issues keep it that way.
Yes, I want to go slow, and I will be considering a keel for straight-line navigation. Hm, well, that’s what I was thinking: first, a proof of concept, and tune it as good as possible, and if it works, just use it. Will sure consider the water rudder, thank you for your feedback!
