Wich Escs would you recommed for a Twin-motor fixed wing?
T-motor F35A BLheli_32 or T-motor AT 55A?
I don´t know if the F35A (copter esc) will work OK on a plane.
Both ESCs should work fine. Just make sure to remove +5V wire from one of the ESCs if you end up using AT 55A.
