Hi, I have a big issue with my yaw values. I am using a Mamba F405 Mk3.5 Mini with Arducopter 4.2.0-dev.
I tried to fly an auto mission with two parts: First part is a mission with a takeoff, some waypoints and a landing with a disarm command. The second part of mission starts after checking if everythings all right and manually rearming. Here comes the problem. After the takeoff, the drone did a yaw turn and took off into the distance till i disarmed it. In the picture of the log you can see the compass log in comparison to the yaw value. EK3_SRC1_YAW is set to compass, so the compass should be the source for yaw, but the compass values don’t change but yaw does.
I marked the two values. Yaw changed in 0.001 seconds from 185.4 to 332.92.
Not only did the yaw values jump, the roll value had also some issues.
Summing up: the pos estimate using the ekf and the actual locationn by gps differed and caused a gps error (as it should) but the problem wasn’t solved.
The link for the .bin
https://htlsalzburg-my.sharepoint.com/:u:/g/personal/paul_ensinger03_htl-salzburg_ac_at/ESKWlmseyC5Omk4MaUxFJgwBbX8tNkpDj_LT8N9Snb5I4g?e=Of07gY
