I am currently looking for a 3D model of a frame suitable for a big copter, ideally with a diagonal between 500 - 700mm, modular or monolithic frame, its okay
Despite searching a lot, finding the perfect big frame 3D print has been a challenge.
Most frames out there are designed for FPV … and it’s tough to find large ones with good designs…
However, I’ve found a few potentially interesting options. On one hand, a modular frame made of carbon tube :
I got a fully 3D printed (and sort of foldable) design similar size to Phantom (and using the same 2312 motors / props). Heaviest and biggest part is the battery enclosure, to take full size 5000-6000 mA 4S.
It flies ok, but I’ve evolved the design into a hex, and it’s my main fun flyer (6 motors = more power = faster response + you’re able to land intact if one motor fails, instead of tumbling out of the sky )
The goal is to build a drone for aerial photography, with high Endurance and long range
With follow hardware :
FC Matek H743
T-motor M4006 380KV
T-motor Carbon props 13"
Esc Tekko32 65A all metal
Raspberry Zero 2 (for 4G telemetry)
3D print Gimbal for Rpi Cam
Lipo Or Li-On 10000mah 6S
(as many people here would suggest) use carbon fibre arms. with 3D printing, the longer the arm, the less rigid it’ll be, causing more vibration and a nightmare to tune the copter. Also the arm attachment points become a weak spot with long arms.
Maybe I will create a custom frame using Fusion 360
I currently have a PC-CF (Polycarbonate Carbon Fiber) Filament from Prusament
I am wondering which adhesive would be best for bonding the carbon fiber tube arms with this material
Epoxy (loctite ?), Cyanoacrylate (like 3M PR100), or Solvent (like scigrip 16)
I used blender, but that’s because I know the program.
Printed mine from PETG (or sometimes PLA when I run out of PETG to print a replacement arm after crash ). PETG you can glue using Cyanoacrylate (Loctite 401 aka “superglue” - will leave white residue, but will hold strongly), I haven’t played with carbon filaments.
Also my designs are screwed together by 6g and 8g wood screws. Arms held by long M5 screws and nyloc nuts.
